20 Most Recent Compaq Evo D300 PC Desktop Questions & Answers
Which driver do I need for Compaq Evo D300 PC
its and HP why not post to HP.,com ? there is no COMPAQ now. D300 no OS stated, what operating system. is it , we cant guess that ever.! and matters #1 , always. you do know all OS are now DEAD up to and including VISTA. right> that means all PLUG and PLAY actions are now dead due to Microsoft cut the cord XP (for example) 3 long years ago. at HP.,com if you looked youd see most compaqs now have zero support, its called RETIREMENT, (me , i scrap them all) its only worth $5 used, at Goodwill stores. why waste hard earned cash on this? find one newer there for $20? some even RAN IBM OS2, operating system gawd hope not you., or XP or Windows 98 why even post lacking a clear statement as to what OS. learn rule 1 on OS. the drivers must match your OS. if not they fail. there are tricks to run older drivers yes, but there is ZERO guarantees that that works. so got HP PC, with no install disk, that be why it can work in all cases. see why? answer well, you can buy them now, cept from horder/scalpers online. and many of those nasty sources are all virus infected. or worse. most the 10 years old PC support at HP are gone but not this one, the D310 was not deleted, dont tell HP this or its gone tomorrow.. hint , down load it all and the books while its still there. (yah)? i guessed XP for you, why must I? https://support.hp.com/us-en/drivers/selfservice/compaq-d315-desktop-pc/316617/model/316619 this page is 15 years old. it dont below there but , thar see be, all fat and ugly. XP is a virus magnet, why run that. you will get infected, for sure. on the net. in minutes. you cant prevent that , now. XP has no updates, no PnP no support and the top reporting site in USA , only 1% of Americans use it now. For good reasons. it's a HORROR. XP has no base line internal protections that , started in VISTA. VISTA is bad too but XP 100x worse. The only OS to run if running old is W7, period. or as id do, run Linux, on this box, for far batter safety. get Full blown, Ubuntu..
6/27/2017 12:44:11 PM • Compaq Evo D300... • Answered on Jun 27, 2017
0answers
Power swich
Just everything unplug and then replug after an hour, it will work and everything will work fine.For further more information contact me back.Good Luck
8/14/2012 3:55:44 PM • Compaq Evo D300... • Answered on Aug 14, 2012
How to fix power switch
You motherboard has been shot so you need to unplug everything for an hour and then replug carefully. I hope after plugin your power switch will work. For further more information or any clarification, contact me back.Good Luck
8/14/2012 3:54:44 PM • Compaq Evo D300... • Answered on Aug 14, 2012
I have a compaq evo
Please refer to pages 64-67 of the following troubleshooting guide to identify the root cause of your problem:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00704816/c00704816.pdf
7/25/2011 3:10:03 AM • Compaq Evo D300... • Answered on Jul 25, 2011
How do I remove the
For that open cpu cabinet cover then you can see harddrive inside the cpu. Disconnect power connection from harddrive and disconnect SATA or IDE cable from harddrive. Then pull the harddrive. Let me know if you need further assistance. Thanks for using FixYa.
4/30/2011 4:59:48 PM • Compaq Evo D300... • Answered on Apr 30, 2011
How do i set the
On this page:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=101&prodTypeId=12454&prodSeriesId=96277
You can download manual and user guides. Download and read it and succes to setup your system!
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
3/9/2011 7:01:41 AM • Compaq Evo D300... • Answered on Mar 09, 2011
Compaq evo D300-power outage in
According to your mail I can understand that your pc fan does'nt work properly.
# If It is your pc-processor fan then first check that the fan connected with motherboard
properly with power cable & don't get loose connection.
you can check that the fan blade don't get touch with any cable or etc.
Finaly you may check cpu fan control in bios settings, and set it on always on mode.
# If the fan is smps fan repair the smps or replace it.
# cabinet fan may not work properly for connection of power cable.
Check the electric line also of your house.
1/4/2011 12:02:59 PM • Compaq Evo D300... • Answered on Jan 04, 2011
Dear sir, i have two compaq
Did you upgrade the ROMpaq before swapping the processors? the bios my not be able to recognize the processor you upgraded to.
http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1282749109495+28353475&threadId=1109463
Hope this helps
8/25/2010 3:13:00 PM • Compaq Evo D300... • Answered on Aug 25, 2010
Ciao ho cambiato il case da orizzontale a
Tenere il mouse sulla barra delle applicazioni, quindi trascinarlo nuovamente orizzontale. Una luce lampeggiante verde è normale.
3/9/2010 10:26:13 AM • Compaq Evo D300... • Answered on Mar 09, 2010
Im trying right now and saying how do you fix
This sounds like you are trying to run a game that needs a more current version of DirectX from microsoft.
Go to microsoft.com and copy then paste your error code on their search window and follow the instructions.
3/9/2010 7:52:39 AM • Compaq Evo D300... • Answered on Mar 09, 2010
My pc blocks on when i turn it on
hi,,
go to BIOS SETUP and see to it if all the hardware that inserted into your pc has been detected.. if not, thats the reason why the screen acounter back..
replace the battery of your motherboard so that the CMOS SETup does not back it again..
thanks for sharing your problem at fixya.com
1/8/2010 8:20:50 AM • Compaq Evo D300... • Answered on Jan 08, 2010
I have a evo300says i need a video card to burn
You can buy a PCI Video Card
11/14/2009 4:27:59 AM • Compaq Evo D300... • Answered on Nov 14, 2009
2answers
Won't boot up. Can't even get to the CMOS boot.3 V
Do you have a modem plugged in one of the slots? if so pull it and retry, do one card at a time, leaving video card for last.
10/25/2009 5:45:00 PM • Compaq Evo D300... • Answered on Oct 25, 2009
Comapq evo tower no boot
have you tried to reset the cmos, there is a little plastic jumper next to the cmos battery (watch battery )on the main board change the position of it for at least ten seconds while the power is off then change back again and sswitch on.
9/15/2009 9:02:47 AM • Compaq Evo D300... • Answered on Sep 15, 2009
Cant run Cricket game
make sure your system configuration suits to that game...........
and install garphic drivers if required..........
if all these are done then you need to copy a file called crack which will be in game disc.......
copy that file to the directry where u have installed the game
8/12/2009 12:38:15 PM • Compaq Evo D300... • Answered on Aug 12, 2009
HI is a 40G hard drive compatible to this model
smould be just remember to set the jumpers corectly
8/3/2009 5:42:28 AM • Compaq Evo D300... • Answered on Aug 03, 2009
2answers
Low local disk space
get a external usb hard drive.you cant do anything to a computer like this chap its going to cost u a little someing.i hope this help u
7/18/2009 3:09:44 AM • Compaq Evo D300... • Answered on Jul 18, 2009
Screen is way to bright
its the same principle as a standard light bulb.they get real bright before they blow out.
6/9/2009 9:00:35 AM • Compaq Evo D300... • Answered on Jun 09, 2009
Stuck during installation of xp
Your HARD DRIVE is likely bad, or your CD is scratched, or your ram is bad, or your CDROM is bad - or some combination of this
5/21/2009 6:14:29 PM • Compaq Evo D300... • Answered on May 21, 2009
Compaq Evo D300 PC Desktop Logo
30 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
evo Compaq
  • evo Compaq
Most Popular Question
im trying right now saying fix
  • Computers & Internet
