20 Most Recent
Creda Europa E010E Electric Single Oven Questions & Answers
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact
www.creda.co.uk.
Where is the thermostat located in the main oven
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Ihave a creda electric oven
Standard power. The voltage is 220V and the 3 black are your hots as well at the 2 reds. The green is your ground. You connect the 3 blacks together then to your hot as well as connect the 2 reds together then as well to you hot the ground is separate. If you looking at a 220v plug the hots would be the bottom 2 post and the ground would be your top lug or the single lug is always ground. Try this link as it may help you visualize the job.
http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/220outlet.html
Do I need to preheat the oven
hi, what you need to do is turn the grill on and leave it on what is happening is all the steam and fat and grease form the cooking you have done in the oven has risen and stuck on the heating element the grill uses, so open your windows and turn the grill onto its highest setting and just leave it after a while the smoke will stop.
You need to do this so that any food you cook using the grill doesnt smell of the smoke thats burning on the grill element.
Dont worry you wont do any harm to it this is a very common problem with combo ovens and grills and the same goes for microwaves with the grill feature so dont worry to much its what happens over time if you dont use the grill much.
So just switch the grill on and leave it it can take upto 20 to 30min to stop smoking but after its burned off all the grease and fat etc it will stop smoking and stop smelling so dont worry everybody who has one goes through this same problem.
let me know how you get on or if you need further assistance ok.
Its best you do this once a week or so to ensure that it dont build up to much as it can really stink the whole place out and if you cook food without burning it all off your food will taste like the smell witch believe me isnt nice, so just leave it all to burn off leave your windows and doors open and after about 20 min you should find the smoke will stop and the smell will go away.
You may find it only takes 5 to 10 min but dont worry no matter how long it takes your not doing any harm your just cleaning the element.
Dont try cleaning it with cleaning products as this can cause harm to the element and could taint any food with the cleaning product you use.
The only real help you can give is that before you turn it on to burn off the grease use a stiff hand brush and brush the element to remove all the dried on loose bits this will then make it quicker to stop smoking.
But other than that just leave it and it will sort itself out.
Broken hinge on Europa oven
try Ausralian Bakery and Pizza, Equipment Importers
122 Whitehorse Road, Blackburn, Victoria, Australia. 3130
Telephone: +61 3 9878 6900
Facsimile: +61 3 9878 6966
They import Europa equipment
