Hi friend, thank you for your post!
I understand that the green light for your lock on your Frigidaire dishwasher is not turning off. I see your question is labeled under the model number GSB5712BC based off the design of that control panel you should be able to hold down the power dry button and the lock light should turn off. If that does not correct the issue I would perform a reset on your dishwasher. You can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
Hey friend, I appreciate your post! Normally the "99+" stands for a longer wash cycle. If your appliance is just constantly showing you this error code, I would reset your appliance. You can do that by unplugging your appliance or flipping the household circuit breaker for ten minutes. If this does not resolve the issue for your dishwasher you could be seeing a problem with your control panel or a sensor. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit. Hope this is helpful. -Matt
Frigidaire Dishwashers • Uploaded on Oct 17, 2013
8 questions posted
438 Questions
252 Questions
192 Questions
187 Questions
117 Questions
