20 Most Recent Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Questions & Answers
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend, I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions: 1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware. 2. Do not add detergent. 3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad. 4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off. 5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher. 6. Close and latch the door and allow cycle to finish. Note: If these conditions persist, a home water softener should be considered. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
7/1/2014 6:21:45 PM • Frigidaire 24... • Answered on Jul 01, 2014
Mildew in washer
Hi Meredith, this is AP! I understand you are struggling with mold spreading in your Frigidaire dishwasher, model PLD2560LCC. The average useful life of a dishwasher is about 13 years, so I would attempt to get a few more years from the dishwasher if you can. Chlorine bleach kills mold and helps remove most mildew stains. Dilute 1 cup of bleach in a gallon of water and scrub the interior of the machine with a stiff brush. Use a toothbrush to get in narrow areas, such as around door gaskets. Wear gloves to protect your hands when you use bleach, and also avoid mixing bleach with any other cleaning product. Run the dishwasher empty after cleaning it to rinse out the bleach residue. If stains remain after mold removal, scrub them away gently with a damp rag and mild scouring powder. Or you could run a cycle with no dishes. Once the dishwasher has completed its initial fill, add 1 cup of white vinegar and complete the cycle. If you find that removes the mold I would open the dishwasher door after each use and allow it to dry out completely before closing it to prevent mold growth. Moisture, bits of food and a warm environment can lead to unwanted mold growth. If you won't be using the dishwasher for a while, such as when leaving for vacation, leave the door open while you are gone to ensure no trapped moisture leads to a mold or mildew problem. I hope this information proves helpful to you, thank you for the post. Thanks,
4/3/2014 7:02:33 PM • Frigidaire 24... • Answered on Apr 03, 2014
4answers
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
1/6/2014 3:10:17 AM • Frigidaire 24... • Answered on Jan 06, 2014
0answers
Frigidaire 24" Built-In Dishwasher (FDB520RH)
Hello, ms I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 7:47:38 PM • Frigidaire 24... • Answered on Oct 27, 2011
Pf code
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
,./;''l
3/7/2011 12:09:16 AM • Frigidaire 24... • Answered on Mar 07, 2011
Hi Ihave problem with my dishwasher. I can not
cccccccccccccccccccccccccccccccccccccccccccccccccccc
2/24/2011 3:24:58 AM • Frigidaire 24... • Answered on Feb 24, 2011
Fridgidaire dishwasher pld2560lcc
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
9/30/2010 12:10:20 PM • Frigidaire 24... • Answered on Sep 30, 2010
Wondering why the dishes when cleaned are gritty
machine needs salt.adrian,,,,,,
7/15/2010 12:57:54 AM • Frigidaire 24... • Answered on Jul 15, 2010
When our dishwasher is in use, it leaks out the front
Take a close look at the door seal, it sounds like this is most likely your problem.
I've used the following site myself for ordering parts with great results, and fast shipping:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158843&diagram_id=1311594#d1311594
I linked you directly to the door parts page, the gasket is Part Number: AP3959846
6/29/2010 3:42:23 PM • Frigidaire 24... • Answered on Jun 29, 2010
Pld2560lcc1 Dishwasher...Control Panel shows 65
pulled the touch pad, go after the middle third with a very small screw driver, cleaned the flex circut with contact cleaner
powered up fine seems to be working again
1/25/2010 6:10:09 PM • Frigidaire 24... • Answered on Jan 25, 2010
Water does not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
12/11/2009 9:50:05 AM • Frigidaire 24... • Answered on Dec 11, 2009
2answers
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
10/21/2009 11:01:04 AM • Frigidaire 24... • Answered on Oct 21, 2009
Dishwasher starts randoming blinking ER message
Call an factory Authorized service company in your area.. New house your move in date will be the DOP... and its cover for a year.. .ER error is a touchpad error... check your dishwasher install it must have an 1 inch of space at the top... I know it will not looks as good but this dishwasher MUST have an inch between the top and the counter...let me know if it helps
10/4/2009 3:12:30 AM • Frigidaire 24... • Answered on Oct 04, 2009
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
44 questions posted
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
mildew in washer
  • Dishwashers
