20 Most Recent
HP GbE2c Layer2/3 Ethernet Blade Switch for c-Class BladeSystem - Switch - 16 ports - EN, Fast EN, G... Questions & Answers
Usb ports (HP Pavilion dv2000 Laptop) unable to retreive data
NO OS STATE is this the XP virus maget , dead for 3 years now?
XP does not work on many USB devices even after the SP3 update
and THE SP3 UPDATE is mandatory. service pack 3
DV2000
id bet you if you booted to linux CD, (knoppix 7 live)
all usb ports work, telling you what, in seconds, XP IS DEAD.
for a fact.
google XP USB dead, (billions of hits for 16 long years)
MS dont support this OS nor VISTA or older.
HP does not support DV200o now its legacy hardware now.
MS plug and play is dead too on XP. per there warnings.
The means all new XP things will be dead, if the maker of said things
does not give you Their soft or that thing..
if hell bent on using XP ,(why) upgrade to W7
then get SP3 there.
https://www.microsoft.com/en-us/download/details.aspx?id=55245
it came new with XP
and was VISTA READY, best is to go W7. !
Goodwill store has $20 laptops with W7 on it working now.
why wait, dump yours, and UPGRADE HW/SW all at once
and WIN.
why to not RUN XP (endless bad and advancing....)
http://www.pcdied.com/XP-sux-sg.html
8/2/2017 12:04:09 PM •
HP GbE2c...
Answered
on Aug 02, 2017
HP Pavillion a6314FPC Prod. GX768AA#ABA, Ser. CNH
I'm not aware that you could bypass alignment. I looked and figure its the only way to tell the computer its ready. I have or had the same computer and printer. Did you download the hp psc software? Looks like its going to image zone instead of doc viewer. There you could convert to text. I'm not sure I have enough information. If the software is working right you should have problems. You may want to try reinstalling. Have you been to the hp site and downloaded the additional software for the printer? Try to give me more info and I'll keep checking so, you can get back to your work. I'm sure I can figure this out, I may have already.
9/25/2009 10:10:59 PM •
HP GbE2c...
Answered
on Sep 25, 2009
Usb ports not working
Check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Also check HP's support section on the web for any updated drivers especially for your laptops motherboard / bios
Any exclamation marks by hardware need fixing before you investigate any further
Once you have done that try some of the common fixes below.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
8/30/2009 5:33:22 PM •
HP GbE2c...
Answered
on Aug 30, 2009
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types
Hp supply central pin connected to the 19V power
- Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
- Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
- Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
- Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
- Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
Look for the driver for my Pc media center M7000 product M7682fr system number RF893AA ?
Visit the HP Support Website:
Go to the official HP support website at HP Customer Support.
Enter Your Product Details:
Enter the product name "Media Center M7000" and locate the specific model or product number. In your case, you've provided the system number RF893AA, which is also known as the product number.
Locate Drivers and Downloads:
Once you've identified your product, navigate to the "Software, Drivers, and Firmware" section.
Choose Your Operating System:
Select your operating system (e.g., Windows) and its version (e.g., Windows 7, 8, 10).
Find and Download Drivers:
Look for the drivers related to your PC's components, such as graphics, audio, network, etc. Download the required drivers to your computer.
Install the Drivers:
After downloading the drivers, run the installation files and follow the on-screen instructions to install them.
Restart Your PC:
After the installation is complete, restart your PC to apply the changes.
If you face difficulties finding the specific drivers for your model or if your PC is quite old and HP no longer provides drivers for the chosen operating system, you may need to consider using default drivers that come with the operating system or upgrading your operating system.
