20 Most Recent
Frigidaire 24 in. FDB635RF Built-in Dishwasher Questions & Answers
Frigidaire dishwasher stuck on heat dry
That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
Dishwasher won't go through cycle
Model number would help alot!
to locate...Open your Frigidaire dishwasher's door and check the inner frame -- left top corner and the left and right sides --for the product label containing the model number.
or Check the inside of the door frame if you don't find the number on the inner frame.
let us know. thanks!
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Why won't my upper arm spin?
Good Afternoon Friend,
I understand that the upper arm is not spinning in your Frigidaire dishwasher, model# FDB635RF. First, check to make sure that your water pressure is between 30 and 120 PSI. If the water pressure is not good in the area your dishwasher is located, try not to use any other water in your home while using your dishwasher. Secondly, make sure that there are no tall dishes that could possibly be blocking the upper arm from spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful.
-Best regards-
WP
Door latch assembly
Good Morning Paula,
I see that you are having trouble with your Frigidaire dishwasher, model # FDB635RF, not starting after you close the door. Might I suggest trying to give the appliance a hard reset. You will do this by shutting the power off at the circuit for at least 2-3 minutes. When the power is restored, if you are still having trouble with the dishwasher starting up, I would suggest contacting either the manufacturer, or your local authorized technician for further assistance.
-Best Regards-
WP
Noisy Hoover hed6612 dishwasher
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
Dishwasher heating element won't turn off
Hello niki4god - I recommend resetting the dishwasher by
either unplugging it or flipping the household circuit breaker off. It is
important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further
evaluate this issue if it was not resolved with the power reset. In this case,
your unit may possibly be experiencing a communication problem with the control
board or a potential wiring failure.
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
Kitchen aid heating water
1) The heating elements +thermostat is the device for heating water.
You must test this device in order to provide good clean dish.
God bless you
