20 Most Recent Planar PR3010 DLP Projector Questions & Answers
you may need to clean it with a soft cloth that should help it may be dust
Planar PR3010... | Answered on Jun 04, 2011
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Planar PR3010... | Answered on Apr 09, 2011
buy a new 1,then look in the menu for it.
Planar PR3010... | Answered on May 08, 2010
try reseting the lamp timer and then replace the lamp if it works
Click print, select printer and select both sides box if it has a box otherwise print one side and re load the paper to print the other.
Office Equipment... | Answered 14 hours ago
Hi myself Steve, i am working professional residing in USA. My primary job is to provide Office 365 technical support. If you are facing any problem while working on ms office then u can contact me . every possible support will be provided. We are available 24/7 and we are offering on a very affordable price so feel comfortable and contact us .
Office Equipment... | Answered Yesterday
press the helpful button and follow me on fixya for more tips
an electronic issue with one of the cartridges
How to Fix Canon Pixma Support Code B200 Error Message
http://www.mytechtime.com/2011/09/canon-error-b200-how-to-fix-it.html
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : alfa_centrino@yahoo.co.id, thanks God bless U
Planar PR3010 DLP Projector Logo
Popular Tags
9 questions posted
Top Planar Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Planar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Office Equipment & Supplies
Most Popular Question
planar pr3010 turns steady orange ready
  • Office Equipment & Supplies
