20 Most Recent
Sharp XR10XL DLP Projector Questions & Answers
Lamp does not turn on
You have something else wrong other than the lamp. I would start with te power supply board first. It may be fried.
My Sharp Projector xr10x will not come on, two LED
The fault seems related to the lamp but it will be good to revisit the replacement of the lamp, check the lens cover section , the lamp cover as there are safety micro switches that need to be active to start the lamp. Also the filter must be cleaned. Check the power supply , check the connectors and fuse. If none of these rectify then the fault can be within the power supply or processor board.
SHARPXR10XL DEALAY PROBLEM
HelloYour problem post is very difficult to understand. Please provide some more details about the fault. What do you mean by this "delay problem"? Please explain briefly the fault you experience with your projector. OK.
I have new bulb i
if you haven't already, try turning it off and then back on after like 30 seconds with the remote?
Lamp does not come on
For the time being at least, I got my projector back on by unplugging the power cord for about 30 seconds then held down the following keys on the projector: Menu, Enter and the Down Arrow and while holding them down, pressed the power key. The projector started up like new with H0000 hrs on the screen like it was a new one. Will be interesting to see how long the bulb lasts! I had been getting a Replace Bulb messge for several weeks before it shut off with two red lights lit. So I tried the above procedure befoer buying a new bulb.
I have replaced the lamp
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
DLP projectors will not turn on
chances are the bimetal circuit breaker has tripped because the projector overheated. clean the filters frequently. if you take the top off (6 screws on bottom, 5 in back, but unplug it first), the bimetal is the red button on the front of the lamp housing. push the red button to reset it and put it back together. turn it on and enjoy!
