20 Most Recent
NEC NP-1000 Projector Questions & Answers
Hec np1000 is failing
The projector ought to be grounded as without a proper ground static could build up and damage either the projector or the video unit connected.
Have you cleaned the IR detector window on the projector?
Hope that helps.
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps:
1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly.
2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue.
3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance.
In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
NEC NP310 projector, can I replace the fan?
Your statement indicates'there is a fan issue'.
It may just require cleaning but may need replacing. Nothing to do with the lamp, unless it has overheated and also needs replacing.
