Follow the below guide :-
Power from the house
Is
there power getting to the dishwasher? This can be difficult to test,
because dishwashers are usually wired directly to an electrical
circuit, rather than plugged into the wall. But at least check for a
blown fuse or a tripped circuit breaker.
Door switch
The
door switch is important because, if it's defective, the dishwasher
won't work at all. To reach it, you need to remove the control panel
cover, or sometimes the interior liner of the door. If it's defective,
you need to completely replace it.
Wiring
Often
the main wiring connection from the house, at the dishwasher, burns and
breaks the connection. If that's the problem, the wires must be
repaired/replaced as necessary. If that's not the problem, check the
wiring to the door switch, the wiring between the door and the lower
part of the dishwasher, and the wiring to the timer. Repair any broken,
burned, brittle, or defective wiring, using the proper appliance-grade
wire and connectors.
Timer or selector switch
Although
it's uncommon, the timer or the selector switch may be defective. If
so, you need to replace the defective part, because neither of these
can be repaired.
Procedure to Check Door Switch
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-door-switch
Procedure to Check Timer
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-timer
If problem persists, it sounds to be Faulty Control Board. You need to check the Board and the Wiring.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
