20 Most Recent
Dane-Elec Meizu MP3 Player Questions & Answers
I got a 1 tb
i think the agent will be the only person to sync it up for you ,
When i turn on my
Dude, This just might be your lucky day...I just spent hours trying to figure this out, in layman terms.
So, here we go!
1) go here to download the firmware
http://en.meizu.com/downfile/S2004.6_Meizu_En.rar
2) open it up with which every program you use to open .rar files
I use WinRAR
3) With your Meizu connected to your PC or Laptop
click on START then COMPUTER you will see the drive which is connect to your MPplayer.
( now follow these directions as I have )
4) go to the firmware file and EXTRACT them directly into the
players root folder. Using the path COMPUTER then HIGHLIGHT THE DRIVE WHICH IS YOUR mp PLAYER
CLICK OK
Then remove Safely from your PC/ Laptop
Please let me know your results
Good luck,
It doesn't play.
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Won't load certain avi files
you need change the video format
you can try use Nidesoft ipod video converter
Nidesoft iPod Video Converter supports so comprehensive video formats
including AVI, MPEG, WMV, MOV, RM, RMVB, DivX, ASF, VOB, 3GP to iPod
video/ iPhone video by building in iPod video converter lots of codec.
download the free trial version
http://www.nidesoft.com/ipod-video-conve..
Blank screen, still on
ah i have the same problem, i havent been able to find a solution even after 5 months. i havent been looking very hard though
Green screen
when i turn on my meizu mp3 player a green screen comes up and says No Resource! Please Upgrade Resource Again!. how do i fix it
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
