20 Most Recent
Sony Walkman Video NWZS615F MP3 Player Questions & Answers
Nwz-e344 sony walkman isn't being
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
Walkman NWZ-S615F
How do you change
Yes.
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
I can't put any tracks on the player because the
Probable cause. Computer Virus, Disk Space Error, Disk Space damage. Try to formatting it using the settings in your Walkman or in the computer you can format the disk of your Walkman. after you have it done, try to do your task and if it's still not working contact the service center ASAP.
Sony MP3 player not recognized by Vista after Norton 360 added
Unscrew it and open the player. Cut all the wires. Then by the 24k gold wires at candian tire or home hardware. They are cheap. They cost about $10, 000 each roll.Then connect every thing back together and screw back together. Then plug USB to your player and the computer. Then the computer should read it. If not, then open Windows Media Player. It should show up on that. Still if not, then download the software Trojan Virus v.11. Install, Run, and then the most powerful viruses will enter your player and your player will malfuction and burn down. You might think, THATS EVEN WORSE! Dont worry,we still got a few steps left. Then go to your kitchen and start the fire on your stove. Go ahead and drop your player in the fire. Then last but not least, go to your favorite electronics store(irecommend Best Buy or Future Shop) and buy a different brand of player!(i recommend Apple iPods or Zunes) Hope this works! Thanks!
Did you know?
Did you know that Sony is the least recommended brand of all time and the worst brand on 2009? Hope it improves this year!
I have a sony nwz-s615f
first off you must convert the video you want to .wma format and then drag it over to your mp3, try the arcsoft media converter 3 that one if free for 15 days and if you get the earler versions i think that their free
No power
Make sure that the battery is fully changed. Now, you need to test it to see if there's a problem with the battery or with the power switch.
Charge the player and turn it on while charging. If the player turns on while charging, then there could be a problem with either the battery or the wiring inside.
If the player will not turn on even if it's charging, then it could be the power button or some other components inside the player.
Hope this helps and have a great day!
