20 Most Recent
Samsung YP-K3JAB MP3 Player Questions & Answers
My mp3 player will not
you have a bad battery, you can get one on ebay and then i can help you how to replace it
Samsung YP-K3J won't boot
We had that issue also. But pushing the reset button on the back corrected it. It is a very small hole in the back of the mp3 player near the headset port.
I cannot install my samsung YP-K3J MP3 Player onto my PC - HELP!!
Try to update the driver of the player.
Go to the START menu.
Click on RUN. type in devmgmt.msc and hit enter.
Make sure you have the player plugged in and the installer CD should be on your CD drive.
Now look for the category PORTABLE DEVICES or OTHER DEVICES.
the YP-K3 should be listed there with a yellow question mark.
Right click on it and select update driver. Follow the prompts to update.
The player should be recognized after that.
Hope this helps!
Installation Cd disintegrated
A local Computer Shop saw my dilemma and loaned me an installation disc. Problem solved. Thank you all for your interest.
Lost installation cd
have you gone to the laptop manufactures web site to see if there is is updated drivers for the usb ... also - when was the last time you visited the windows update site (if you have windows) or the update site of the MAC and or Linux os update repositories.
have you tried other peripherals in the usb ports ( to see if they in fact work)
just some ideas.
Unable to Safely Remove YP-K3J
the people that say to ignore the safely remove device - are mistaken.
all i can suggest is go to the manufacture of the computer and make sure all your device drivers are up to date.
and depending on your OS - windows update site or the linux / mac / other repositories to make sure all those are updated as well.
Samsung yp-k3jab BRICK.
well - strange as it may seem - it wasnt as dead as it appeared to be... having the prior evening plugged it into another machine to see if it was in fact a usb port issue... it appeared to be the brick i thought it was. (non-functional).
scanning through all the messages from others i came upon one that said to hold some button for 5 to 50 seconds while pluggging it in... now as i said, i did try numerous other things prior ... but for some reason other than ( cursing / swearing / threatning the bricks existence on this plane ) it now works. all i can say is thanks to those several others who complained about the same thing.
thanks.
kgmetcalfe
note: still does not explain WHY it did what it did. and there is NOTHING!! at all on the manufactures web site. just one more reason to perhaps do a lot more research before you purchase their product(s).
Mp3
the media studio wont recognise the player unless you install the program? why not install it then? does it ask for money?
