20 Most Recent KDS K-24mdwb LCD Monitor Questions & Answers
3answers
Can i buy a screen
Sure, You have many choices out there. I even saw a repair kit on Ebay for your monitor. You just can't purchase on this site.
3/23/2015 1:46:43 AM • KDS K-24mdwb LCD... • Answered on Mar 23, 2015
2answers
No power to my KDS k-24mdwb monitor, can this be
You can try if you have proper tools and soldering skills.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
3/23/2015 1:14:33 AM • KDS K-24mdwb LCD... • Answered on Mar 23, 2015
2answers
Bad inverter
Inverter Board? You can try shop that repair electrical things or the TV shop...
3/22/2015 9:53:53 AM • KDS K-24mdwb LCD... • Answered on Mar 22, 2015
I have a KDS XF-9e that is not working with two
Disable cross fire and see if the issue goes away.
3/3/2017 2:45:40 PM • KDS Computers &... • Answered on Mar 03, 2017
No sound
then your speakers are bad,not plugged in or not plugged in properly
6/22/2015 4:01:39 AM • KDS Computers &... • Answered on Jun 22, 2015
How to brighten monitor
i have a few thing to help you with this problem, but first if the monitor old, used a lot or left on all the time than it is time for new on. first right click on screen using the mouse than go down to screen resolution than find the detect button after thats done go to Identify select that one, after you done all that than go to advanced settings and open the folder, than check the adapter, monitor, troubleshoot, color management, than select color management check all settings. 2 way is to go to control panel open color management folder, for your general information for you monitor and other options you mite want to review understanding color management settings find advanced tab find calibrate display, it will run a lot of tests and have you answer some question about visual site and what you like in the settings of the monitor. you mite look in to video card manufacture and see if they have any tools for the drivers game apps or programs that runs other than video card drivers, like i have nvidia video card and i went to there website and downloaded so software, nvidia control panel for gamers, 3d adjusting color settings and video image settings, change the aspect ratio, resulation, refresh rate, lots of tools for games and gamers and i do not play a lot of games but i like to have a lot of option that i would not have had before. thank you rod PS make sure all drivers are up to date you will find it in control panel and than open device manager and find video drives, monitors, display adapter.
3/15/2015 7:02:54 PM • KDS Computers &... • Answered on Mar 15, 2015
2answers
KDS k 72mb
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
12/12/2014 9:31:20 AM • KDS Computers &... • Answered on Dec 12, 2014
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
what kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
9/10/2014 4:29:08 AM • KDS Computers &... • Answered on Sep 10, 2014
How do you clear memory??
you probably need to clear the history as it is probably full
9/10/2014 4:27:28 AM • KDS Computers &... • Answered on Sep 10, 2014
Why won't my K917s 900p monitor show my MAC Pro screen?
get rid of the new installation it is not compatible with your system
9/10/2014 4:26:34 AM • KDS Computers &... • Answered on Sep 10, 2014
Where can I get kds computer monitor repair?
try any computer repair shop
9/10/2014 4:24:33 AM • KDS Computers &... • Answered on Sep 10, 2014
I need the dc in power cord for modelax191 rad-9
the power cord is the same for all makes and models if you have one then i bet it will work on yours
9/10/2014 4:22:27 AM • KDS Computers &... • Answered on Sep 10, 2014
How can I fix monitor whe it says no signal
check if your system unit is sending signals to the Display unit(Monitor). if not giving signal. check your CPU's Power cable,RAM, blow you system with air gun and turn it on again
9/1/2014 8:18:00 AM • KDS Computers &... • Answered on Sep 01, 2014
Comes on lokks dim stay few mintues then shutdown turn power off then back on does the same thing
separate the wiring. Touching wires causes cross-talk and signal disruption.
6/22/2014 5:14:19 PM • KDS Computers &... • Answered on Jun 22, 2014
Aquasource shower head
Clockwise, I shouldn't wonder.
6/12/2014 10:20:36 PM • KDS Computers &... • Answered on Jun 12, 2014
0answers
K-92BW
Be the first to answer 6/7/2014 3:39:18 AM • KDS Computers &... • Posted on Jun 07, 2014Be the first to answer
KDS K-24mdwb LCD Monitor Logo
Popular Tags
3 questions posted
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • KDS Computers & Internet
Most Popular Question
buy screen
  • Computers & Internet
