these monitors are tightly held in place by clips. After removing all the necessary screws, use somehing like a credit card to pry open the lid. Just need to be careful not to crack the case, or your hand.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Not too much info here. Based on your statement, I'm guessing you are trying to connect a digital camera to your monitor to display pictures on it.
1) Does the monitor work fine as a monitor on its own?
2) Make sure you're on the right display/input setting on your monitor.
3) How do you know the camera's TV-out function is working? Have you tried it on other TVs?
Its possible that the camera is not in display mode. Its also possible that the camera's TV-out is not working. Its also possible that something about the output from the camera is not compatible with your monitor. I would try the following:
1) Test the camera on another TV to make sure the TV-out is working.
2) If its working, go to the appropriate input/source setting on your monitor, before connecting the camera. Then connect the camera, when the camera is off. If nothing displays then turn the camera on, and see what happens.
If that doesn't work, it may be possible that your camera displays in a different set of settings (resolution, etc) than your monitor is able to display. Also I would check the manual for your camera to make sure there isn't some way to adjust the settings.
there should either be a menu button on your TV or on your REMOTE
after its pressed ...go to picture and there you can adjust the screen to your preferences.
FIRST WE DO NORMAL AND LATER TRUE CAUSE.
gee that is normal on all monitors and by Energy Star laws too.
the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days.
and the OSD button goes dead after. that. too. fooling the untrained.
here is the first tests, NO PC connected at all
power on see power light glow correct color
then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works.
if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok.
this monitor is very very old, 2004?
it has CCFL back lamps not LED<
and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now.
this is what they do: all do , used fully.
1: goEs dead forever, (vast did)
2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD.
3: DIM BULBS (like me. lol)
4 TURN YELLOW FOR WHITE screens.
5: STROBEs. (FLASHes)
AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
power on and power on led glows normal , not yellow or flash.
then this happens splash. attached, 2014 made.
then that tells you screen is NOT DEAD is it? now? here?
(PC is dead or missing)
NO connections on 1 or more inputs.
NO sync
no signal
OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad.
if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused.
that means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
WHY DOES THIS SEARCH SHOW.The Viewsonic VSR220 no such thing.?Turn the monitor around, 180 and see the TAG sticker with real model toldno PC told , what PC is this?this ? VSD (D key is next to R) so huge typo"?https://www.viewsonic.com/eu/products/lcd/VSD220yes that is a PC (android)but can do monitor like duty. too.it needs service.if screen is dead, it has power problemsas the screen must at least show a viewsonic splash as power is turned on.try it on a 2nd room AC power jack yet:?if in warranty take it back to the storeor call viewsonic for help.the android PC can use an HDMI cable to a PC and works as a monitor.too.the manual states"4.5 Connecting to HDMI-compliant Devices via MicroHDMI InputHDMI (High-Definition Multimedia Interface) is a compact audio/videointerface for transferring uncompressed digital audio/video data. You canobtain the best user experience for video playback and gaming via HDMI.VSD220 is equiped with a micro HDMI input for connection to an externalHDMI-compliant device. You can connect your PC, notebook, Blu-ray playeror any other HDMI-compliant device to VSD220 for high-definition videodisplay."
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets
I hope you can disarm it, comment the results
Greetings Franco Dosil
Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas
Espero que puedas desarmarlo, comenta los resultados
Saludos Franco Dosil
http://www.viewsonicglobal.com/public/products_download/36/29622.pdfhttp://www.viewsonicglobal.com/public/products_download/36/29639.pdf
The problem is seems to be in power supply section. it may be need to repair by electronic technician, after using any monitor 5 to10 years there may be power section or lcd panel may be damage.
