20 Most Recent
Samsung 80092 Microwave Oven Questions & Answers
I lost the instructions for my Samsung combi
Go to Samsung.com. Then go to products and then to your microwave. they have all the instructions for every thing they make. If still cant find it, go to contact page and 1-800 number and ask them how to get a new instruction book they should be able to direct you.
HOW TO CHANGE OVEN LIGHT
Replacement of the
lamp should be carried out by a qualified appliance repair service.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
But here is a basic method if you are
mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its
position is adjacent to the vent holes that it shines through.
If
you feel confident, disconnect it from the mains power, remove
anything in the cavity.
Remove the microwave cover. Purchasing a
new replacement lamp will be useful as it will give you an idea of
what it looks like. Locate the dead lamp remove the lamp and fit the
new one. Replace the covers. Plug it back in and try the lamp by
opening the door.
Hope this helps.
My oven shows the numbers in the window and only
to solve this problem you just haveto follow the following steps:
disconnect the oven from the electric circuit,
take a 10kg hammer. lift the hammer to the height of your head, strike the oven with the hammer 22 times. now put the oven on the road, run your car over it. now take the oven and use it. you will see it functioning properly.
recommend this to all your friends. you got my advice free. therefore do not charge anything from any body. love your neighbour.
bye.
sabu karipuzha
I need a glass plate
You can source these plates from any of the kitchen accessories shop. If you meant that the main glass plate of your microwave is broken then you might have to contact Samsung service /support.
Contact the local dealer.
1 week old just stoped working?
Hello there:
If you have checked out the fuse and you are 100% sure that it is ok than you will want to have the door switch checked out the door switch completes the electrivcal circuit when the door is closed and if it is bad there will not be any power to the unit at all. so it can give you a faulty indication a lot of people misdiagnose the door switch thinking there is or should be power or lights when the door is open ok ?
And if this still does not work then the next thing to check out after this will be the power inverter ok
Hope this all helps out
Best regards Michael
Which brand microwave oven is best in the market
That kind of depends what you want. Kenmore, Whirlpool and Fridgidare are the best value. Maytag, Amana, Jenn Aire are a little higher end. LG and Electrolux are the higher end. When it comes down to it most of them have some of the same components. Keep it simple. The more bells and whistles, the more likely it won't last. Sometimes the cheapest ones are the best. Personally, I have a countertop unit by Emerson. 10 yrs old, no problems.
Microwave oven making popping noises
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The
waveguide cover (also called a spatter shield) is usually about the
size of a playing card and often held in place by a plastic rivet.
In some models it is a
larger stirrer cover type made of thicker plastic in the ceiling of the
oven.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of
the oven is chipped or charred, it will have to be sanded smooth and
clean and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
If your waveguide cover
is burned, it will need to be replaced. It provides important
protection for the magnetron.
Please write back with
your brand and model number if you need further help.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Samsung microwave oven model #ME21K7010DS/AA
Judging from reviews of this model on Samsung's website, this is a common problem. Does it happen during or after using the cooktop or range below the microwave oven? In particular, is it most common when using the burner directly under the microwave oven control panel?
If the issues are correlated to heat or humidity from cooking on the range top, I would suspect problems with moisture in the keypad circuitry. I would consider cleaning the controller board key panel connector area with 90%+ isopropyl alcohol (this is an internal service on a circuit board that is most likely susceptible to damage by static electricity, so it should be done by someone who knows how to service electronics). This should remove contaminants that could cause current leakage between keypad connections (spurious keypad entries) in humid conditions. Let the board dry thoroughly before reconnecting.
It's also possible that moisture is getting into the keypad assembly. This would be a design/manufacturing flaw. I would guess the oven is out of warranty, so the fix would be to put the keypad in a dessicator for a day or so, then seal the edges with RTV Blue or a similar caulk that does not release acetic acid (vinegar) during the curing process. (Acetic acid even in vapor form may corrode the silver contact material in the keypad.) Do not seal the connector, just the edges of the flex ribbon layers where moisture can get into the key membranes.
In the meantime, always use the microwave oven fan when cooking on the range. This will help to keep the controller cool and dry. (Samsung's troubleshooting guide says the fan will turn on automatically if the microwave oven gets too warm from cooking underneath it.)
3/16/2023 8:51:25 PM •
Samsung...
Answered
on Mar 16, 2023
Hi i have Samsung Model GE0103MB microwave and i took it for repairs and the bottom switch is not engaging
It sounds like you are having difficulty with the bottom switch on your Samsung Model GE0103MB microwave not engaging with the door release button. This can prevent the microwave from functioning properly and could be caused by a few different issues:
- Make sure that the switch is properly connected to the door release button. The switch may have been installed incorrectly during the repair process, which could prevent it from engaging properly.
- Check the door release button to ensure that it is not damaged or malfunctioning. The door release button could be preventing the switch from engaging properly.
- Check the wiring connections to the switch and door release button to ensure that they are secure and not damaged.
- If you are having difficulty assembling the microwave, I suggest you to try and get the service manual or a diagram of the assembly process for your specific model GE0103MB. You can try searching for it online or contacting Samsung customer service, as they may be able to provide you with the information you need.
- If the problem persists, you may want to contact a qualified technician to service the microwave and inspect the door switch and door release button.
It's important to note that working on a microwave oven can be dangerous and should only be attempted by someone who is familiar with the inner workings of the device, and have the proper tools and equipment.
1/14/2023 10:45:45 PM •
Samsung...
Answered
on Jan 14, 2023
