20 Most Recent MSI Megabook M670-046US Notebook Questions & Answers
M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
9/4/2015 2:06:29 AM • MSI Megabook... • Answered on Sep 04, 2015
Printing problem on MSI notebook
Check you have printer services running in your PC.
Click "Start" Button.
Select "Run"
Type "services.msc"
scroll down till you reach "Print spooler"
Make sure you have "Startup" as Automatically" selected.
if you are having problem with driver then
Here is the link for HP laserjet 1006
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3435684&lc=en&cc=us&dlc=en&submit.y=8&submit.x=8&lang=en&cc=us
Select your Operating system and Download it.
Here is the link for Canon Laser Shot LBP 2900
http://software.canon-europe.com/products/0010177.asp
Hope it fix your problem.
12/28/2009 9:38:08 AM • MSI Megabook... • Answered on Dec 28, 2009
Battery is not charging when plugged
It is critical that you report early problems immediately to the manufacturer, some like DELL have a 15 day return policy. Otherwise you must follow their warranty repair instructions. Could be the battery, the charger or the motherboard.
1/23/2009 2:08:23 AM • MSI Megabook... • Answered on Jan 23, 2009
Comp wont run off battery
well I would check the contacts that the battery has with the laptop, flip it over pull out the battery and look at the metal tabs that go together make sure they are clear from any debris.
1/23/2009 1:57:21 AM • MSI Megabook... • Answered on Jan 23, 2009
How to restore a msi u135dx notebook to factory settings
Reinstall Windows
1/8/2016 7:15:33 PM • MSI MegaBook... • Answered on Jan 08, 2016
0answers
0answers
0answers
I have a problem with blu screen
explain what happened in detailed
10/21/2013 9:59:19 AM • MSI MegaBook... • Answered on Oct 21, 2013
Laptop no sound
Hi Scarlet,There could be many possibilities for this. Since its a new Laptop, nothing could have gone wrong with Hardware or Software. But could be some configurations. Please let me know the following details.What is the Operating system. If windows, do you see the speaker icon on the right side bottom of the screen. Check if its muted. Or increase the volume. Hope this solution worksRegards~SmokinJoe~
5/11/2013 8:28:50 PM • MSI MegaBook... • Answered on May 11, 2013
0answers
Msi ms-no82
Be the first to answer 3/18/2013 3:47:09 AM • MSI MegaBook... • Posted on Mar 18, 2013Be the first to answer
2answers
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to that. if you get a display on your desktop monitor then that means your laptop screen needs replacing. If you get no display on your desktop monitor then that means the GPU chip in your laptop has gone bad.
9/12/2012 1:54:16 AM • MSI MegaBook... • Answered on Sep 12, 2012
I have a hard time seeing my screen in XP - where do I go to adjust the brightness of the screen
How hard a time is it? Maybe your screen is going bad or the LCD Inverter is bad.Press and Hold the FN function key located at the lower left portion of the keyboard then hit the key that makes the display brighter or darker. There will be one key for brightness and one key for darker. Normally it will have the icon of a sun or washer with the up or down arrow.
4/30/2012 8:37:58 PM • MSI MegaBook... • Answered on Apr 30, 2012
I can't find how to adjust the brightness of my screen in Window Xp on an MSI laptop
Press and Hold the FN function key located near the bottom left on the keyboard then hit the key that adjusts the brightness.It will be one key for brighter and one key for darker. Look for the keys they will have the icon of a round sun or washer looking circle with the up or down arrow on it.
4/30/2012 8:34:00 PM • MSI MegaBook... • Answered on Apr 30, 2012
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
MSI Megabook M670-046US Notebook Logo
5 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MegaBook MSI
  • MegaBook MSI
Most Popular Question
printing problem msi notebook
  • Computers & Internet
