20 Most Recent MTX Thunder 4250D Car Audio Amplifier Questions & Answers
you can add an apex and an eq
MTX Thunder... | Answered on Dec 09, 2011
the deck, eq, epie, apex, amp, wires and sub
MTX Thunder... | Answered on Aug 04, 2010
the Kenwood exleon line is really good
4 or 8 guage i use 4 guage for mines
yes i have the 200 dollar epie cause it shows me the voltage of my battery and shows you the spl in your car.
you should go for a 4 channel amp that has 500 watts and try to go for MTX
you can try check out MTX.com
the ground wire should be no longer than 3 feet the shorter the better just make sure it touches bare metal and yes it needs to be the same guage as the power wire
you can try the new soundstream T5 or a MTX 9500 but the T5 would sound deeper and cleaner
it could be there is no air circulation or the fans are broken
yes you can but the best thing is to use a toggle switch so you can always turn it on and off
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
could be the wires is bad or someplace the power wire is grounding out or the fuse or fuses is blown. or could be not enough voltage but highly doubt it.
MTX Thunder... | Answered on Aug 03, 2010
yes you shorted the output transistors and replacing them will fix your issue. inside the amp you will find three legged transistors that mount to the amps body/heat sink. replace all of them.
good luck man.
MTX Thunder... | Answered on Jan 31, 2010
HUF75339P3-ND
THE ABOVE LINK WILL TAKE YOU TO THE DIGIKEY PAGE THAT HAS YOUR MOSFETS YOU ARE LOOKING FOR IN THIS AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
MTX Thunder... | Answered on Jan 06, 2010
different companies use different numbers so you should try to cross reference with other resistors you could probably call an electronics company and have them look it up for you
MTX Thunder... | Answered on Jul 05, 2009
MTX Thunder 4250D Car Audio Amplifier Logo
Popular Tags
29 questions posted
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
out car go bad
  • Car Audio & Video
