20 Most Recent HP Compaq 6710b Notebook Questions & Answers
What is the center pin
so what is the full service tag data? 3710b or 6710b, you posted both , and is not complete at all those numbers, (vast submodels exist) the former number dont fly.. if the PC run ok, on AC pack (HP spec, pack) no battery installed then it (pack) and the PC are ok (no bad jacks) leaving 2 things, battery (that love to fail) or the charging chip you can not unsolder, ever and replace. the center pin, seen on the schematic https://elektrotanya.com/hp_compaq_6510b_6710b_inventec_dd1.0_dosxx_dunkel_1.0_rev_a02_sch.pdf/download.html or is the AC line loss early warning. (tells PC to go to battery early) this signal ends up on the charge chip called Charge Control line. the schematic is free. have no battery pack schematic that drives this pin but its tells the PC to go to (battery early, as power fails AC) the changer over is not instant so they this pin tells the PC early, the power is failing my guess, it can detect power loss, in the pack, in 2 milliseconds flat. (power loss early warning) limit-sig-3j5bl5h152snddnteogw53vw-5-0.jpg
10/5/2017 8:57:05 PM • HP Compaq 6710b... • Answered on Oct 05, 2017
Hp compaq 6710b is not powering when i put the powerpack
Does that mean it DOES power up without the battery? Or by power pack do you mean the AC adapter? Replace it. either way
4/9/2014 11:18:07 PM • HP Compaq 6710b... • Answered on Apr 09, 2014
Keyboard Compaq 6710b. "V" key
Try using an external keyboard...provided that it works you should consider replacing the laptop keyboard that is also considering the age of the system as in if you still want to invest in it or use the external keyboard and or onscreen keyboard as the 'v' alternative
12/7/2013 5:32:31 PM • HP Compaq 6710b... • Answered on Dec 07, 2013
3answers
I have a HP Compaq
Try downloading the latest bios for the laptop, i had the same problem of windows reporting that the battery was fully charged when it was actually empty, a bios update fixed the problem
9/18/2012 6:33:11 AM • HP Compaq 6710b... • Answered on Sep 18, 2012
I lost my finger in accident now i cant start my laptop how to start
Have you tried using another finger ?
9/14/2012 1:31:10 AM • HP Compaq 6710b... • Answered on Sep 14, 2012
My HP Compaq 6710b Notebook will not power
you need a new motherboard i'm afraid
1/15/2011 3:30:32 AM • HP Compaq 6710b... • Answered on Jan 15, 2011
No sound from my laptop
More info please.....
New windows install?
have you had sound?
Is sound set to mute?
Is the correct playback device set as default?
control panel/sound / and check the default playback device
7/18/2010 7:57:25 PM • HP Compaq 6710b... • Answered on Jul 18, 2010
BLUETOOTH SOFTWARE FOR YOUR PERIPHERAL DEVICE
i want install my bluetooth peripheral device can yu help me
10/15/2009 12:19:41 PM • HP Compaq 6710b... • Answered on Oct 15, 2009
How High voltages can damage the motherboard of HP6710b?
Re Laptops
The tolerance level is around 10% of the input voltage of the charger for a laptop
So check the rating plate of the charger.
If it says 19v and you have hit it with say 23v you should get away with it however if you hit it with 30v+ then there is a good chance that the voltage regulator circuit is fried
Re Mains Supply
If you are talking about static electricity hitting components then all bets are off as they can run into 1000's of volts.
If it was a lightening strike then again you can get some really big voltages down power and phone lines etc.
Normally Routers and Modems get crocked first.
What died !!
6/21/2009 8:22:46 PM • HP Compaq 6710b... • Answered on Jun 21, 2009
No power at 19.5 VDC jack
You will need to call our technical support line on 0845 20 20 118. Click Here for help
2/17/2009 4:43:31 AM • HP Compaq 6710b... • Answered on Feb 17, 2009
2answers
HP Compaq 6710b
It should be the third button to the right from the top byt the power button. Here is a link to a pdf that shows where everything is on your model.
http://h20195.www2.hp.com/V2/GetDocument.aspx?docid=0900a5a5821030aa&cc=bg&lc=bg
1/4/2009 8:15:55 AM • HP Compaq 6710b... • Answered on Jan 04, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered Yesterday
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
HP Compaq 6710b Notebook Logo
18 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp compaq
  • Computers & Internet
