20 Most Recent
Toshiba Satellite P205D-S7479 Notebook Questions & Answers
CD driver for my laptop cannot be found
try deleteing the upper and lower filters of your CDROM drive.
here's the procedure:
Click Start and then click All Programs.
- Click Accessories, and then click Run.
- Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
- In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
- Exit Registry Editor.
- Restart the computer.
9/25/2012 7:29:13 AM •
Toshiba...
Answered
on Sep 25, 2012
BIOS PASSWORD ON TOSHIBA P205D
u have to open the back covr of ur laptop then take out the CMOS
battery(type of big button cell) for abt 5 secs and insert it back and
then restart ur system.
if u do this correctly the password willbe reset.
let me know if this helps
4/18/2012 8:15:55 PM •
Toshiba...
Answered
on Apr 18, 2012
My cd drive wont read disks, but it will allow me
There could be several causes, but because you mentioned your internet as a second symptom, it leads me to believe you may have a virus.
What exactly occurs when you try to read a disk for the second time? Do you get an error? Does the drive letter disappear?
I suggest you obtain a decent anti-virus, put it on a USB stick, and install it on your laptop from there. Avast! is free, as is AVG anti-virus. I recommend you get a free trial of a paid copy, however, so that you can do a full scan for root-kits, MBR, etc. Avast! Internet Security is good, as is Trend Micro and/or Norton.
3/27/2010 7:52:26 PM •
Toshiba...
Answered
on Mar 27, 2010
When i try powering up
this is usually indicative of a battery that is faulty and wont hold sufficient charge.
and usually - if the battery will not charge - it is the DC power jack that has failed.
does the "charging" light come on when it is plugged into the wall?
12/14/2009 8:45:22 AM •
Toshiba...
Answered
on Dec 14, 2009
Power supply issues, wont charge.
Dear,
This is isse with your power adaptor. Its not having the capacity to light up the scree while working. But it is having the capacity to charge you battery. You have to replace your power adaptor
10/13/2009 8:09:23 AM •
Toshiba...
Answered
on Oct 13, 2009
Black colors turns to red
It is not due to bad connection it is due to bad software driver version of graphics driver. I recommend you to install correct version of graphics driver like Intel's driver.
7/21/2009 6:23:15 PM •
Toshiba...
Answered
on Jul 21, 2009
DVD/CD Drive will not read discs
it is likely that your dvd drive is defective. the drive is held in by one screw either on the bottom or under the keyboard. once you pull it out you will see the model number for it and then can find one either at a good computer store or on ebay and replace it and your problem will be fixed
7/15/2009 5:09:59 AM •
Toshiba...
Answered
on Jul 15, 2009
Toshiba P205D
either screen or viedo card has gone out try plugging it into a alt screen and see if it shows or not if it does I would say your screen took a floop or if it does show on a atl screen I would suggest you have prombally lost your veido card let me know la la linda
2/5/2009 7:22:10 AM •
Toshiba...
Answered
on Feb 05, 2009
