20 Most Recent Toshiba Satellite P205-S6347 Notebook Questions & Answers
I have a Toshiba Satellite
Satellites are notorious for video hardware failure. I have one, and it does the same thing. Usually, when I move the lid during bootup, the screen comes on. But the problem lies in the video chip itself - the Satellites tend to overheat, causing the video chip to become unseated. Google it, you will see what I'm talking about. Type in, satellite p205 video problem or something. Good luck.
2/6/2018 5:43:58 PM • Toshiba... • Answered on Feb 06, 2018
The screen gets grainy
In most cases,it is the signal cable or the screen itself,so change the screen first if the problem still persist,get the signal cable changed for u..
11/21/2013 10:54:07 PM • Toshiba... • Answered on Nov 21, 2013
Download mft defrag
defrag is in Windows already. Do a search from the Start button.
8/5/2013 6:08:55 PM • Toshiba... • Answered on Aug 05, 2013
I do I cancel my finger swipe and have my laptop boot up upon open up?
BIOS passwords can be reset or removed in two ways:1. using software 2. using hardware.I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.You can download it here:http://www.syschat.com/download120.html&act=downCmosPwd - Cmos password recovery toolshttp://majorgeeks.com/CmosPwd_d239.htmlYou will need to create a bootable Dos, or Linux or NT cd in order to run them.Good Luck!
9/8/2012 2:40:07 AM • Toshiba... • Answered on Sep 08, 2012
I forgot my password for
Boot from the Windows CD and reinstall the OS.
5/8/2011 11:25:04 PM • Toshiba... • Answered on May 08, 2011
Are there systemic hard drive
Your right,,some models do do this ,i dont know if yours is one of them,I wouldnt buy Toshiba,asus and acer and HP are better brands with less failure rates and longer lives
3/10/2011 8:22:44 PM • Toshiba... • Answered on Mar 10, 2011
My camera will not start
Hi, kindly get the driver here : www.updrivers.com/drivers/...Camera/Toshiba/24/341.html
Regards, Jay
2/18/2011 5:52:40 PM • Toshiba... • Answered on Feb 18, 2011
No puedo encontrar los drivers para toshiba
Hola,
Bienvenido a Fixya
. Si necesita a un conductor para su satélite p205-s6347 de toshiba sólo clic en el lazo abajo. Seleccione sólo su sistema operativo como Gana 7 de 32 bits.
Haga clic aquí. Gracias por utilizar Fixya.
2/16/2011 9:40:56 PM • Toshiba... • Answered on Feb 16, 2011
To resetting the bios for
To reset the BIOS read the information from this link .
In case of your HP laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
12/22/2010 8:34:05 AM • Toshiba... • Answered on Dec 22, 2010
To reset the bios password
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
12/21/2010 11:22:21 AM • Toshiba... • Answered on Dec 21, 2010
Monitor won't go on. blue screen. but exteral
Sounds like it could be a possible problem with your driver. Find out what type of graphics chip is on the laptop and go to their site to get the most recent driver for your operation system. Hopefully that will help you out
8/19/2010 11:07:09 AM • Toshiba... • Answered on Aug 19, 2010
WiFi won't turn on.
i think it is broken... you can purchase a dongle wifi and use that as your connection.
7/1/2010 3:40:29 AM • Toshiba... • Answered on Jul 01, 2010
Won't restart
start the laptop by booting with the windows disk and choose repair install you should find this will work without any problems........cheers from scott
6/29/2010 10:51:20 PM • Toshiba... • Answered on Jun 29, 2010
One side (r) of screen flashes on wth TOSHIBA LOGO
Chec your control panel for your device section you may have it in external video mode.
call your local computer geek!!
6/29/2010 10:24:47 PM • Toshiba... • Answered on Jun 29, 2010
Installed 2 2g memory chips rated 6400 (comes with
Maybe his OS is a 32bit version. Thats the usual problem with the 32bit OS,,it couldnt read memories greater than 3gig. Try changing it to a 64bit OS..i hope this helps
4/27/2010 6:43:19 AM • Toshiba... • Answered on Apr 27, 2010
How do I change the hard drive
Please check the bottem side of the laptop and see the cover mark as plates like hdd open the cover and u will see your hdd once u see your hdd remove the screws and can unmount it from the laptop then you can change with the same type of hdd like if it has ide or sata
4/18/2010 6:07:41 PM • Toshiba... • Answered on Apr 18, 2010
Computer - I am being denied access to many spots
Do you have Adobe Acrobat Reader installed on the computer? If not go to www.adobe.com and click on "Get Adobe Reader" to download and install.
4/13/2010 10:24:16 PM • Toshiba... • Answered on Apr 13, 2010
4answers
I need to replace a couple of letter keys on my
if your problem is (the keys writing are worn out) then you can neatly write on it, but if the keys (some ) are not working, then your keyboard will not work, even tyou replace the keys...the plastic tracks can be damaged, and only it can be replace by changing the whole keyboard...check out on www.toshiba.com ..if hard to get 1, plug a usb external keyboard
4/2/2010 4:53:05 PM • Toshiba... • Answered on Apr 02, 2010
Screen turn red and fuzzy, hard to read
then the problem is from the screen so what you will have to do is to change the the screen before it become worsen ok
3/6/2010 7:55:40 PM • Toshiba... • Answered on Mar 06, 2010
My friend got into my settings and did something
he easiest thing to do is get your friend to type in the password to enter the BIOS, and hahve him reomve the passwords. (its his fault, let him fix it!)
If he won't do it, you'll have to locate a socalled CMOS switch on the motherboard. (which involves looking through manuals, opeing the laptop case, finding the switch, and after that manually chane al the BIOS settings back to what they should be) This switch will reset our motherboard to default settigs so the passwords wil be gone, but s said, it's a lot of work and there is a risk your PC won't run properly with these resetted settings.
If it was my laptop I'd get really mad at the friend and kick him until he fixed it, but it's your call.
12/17/2009 9:50:42 AM • Toshiba... • Answered on Dec 17, 2009
Toshiba Satellite P205-S6347 Notebook Logo
32 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
installed 2 2g memory chips rated 6400
  • Computers & Internet
