20 Most Recent
Acer Windows Vista TL-562G Notebook Questions & Answers
I tried to uninstal a program, but it didn't let me
You should always remove and uninstall programs
from your PC that you are not using.
It could be beneficial to your computer's
productivity and functioning to free up space.
You run the risk of running out of space on your computer if
you add too many programs without uninstalling some.
It is a relatively easy process, but you should be sure you
are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs."
Click "Control Panel" and "Programs" and
"Programs and Features."
Browse the list of programs on your computer and select one
that you want to remove.
Click "Uninstall." You may be prompted for
permission from the administrator to remove the program. Enter the administrator
password or confirmation if necessary.
Check the properties of the program if it is not listed in
"Programs."
You can do this by right-clicking on the program desktop
icon and selecting "Properties." Check to see if the program is
compatible with the version of Windows that you are using.
Click "Start" and "Run," to manually
remove the programs if the uninstall option does not completely uninstall the
program.
Type "Regedt32" in the box and click
"OK."
Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall"
registry key and click "Export" under the "File" tab.
Click "Desktop" on the "Export Registry
File" dialog box.
Type "Uninstall" in the "File Name" box
and select "Save."
The left panel of the Registry Editor will display the
programs that are currently installed.
Right-click the key in the left panel of the Registry Editor
window.
Click "Delete."
Click "Yes" when you are asked to confirm deletion
of the program.
Click the "File" menu and select "Exit."
This will exit the Registry Editor.
Click "Start" and "Control Panel" and
click "Add or Remove Programs."
Confirm that the program is no longer listed here.
and
you might have other web search toolbars interfering
Create the menu tab on your
homepage right click in the top toolbar you should see a number of toolbar
options select the menu tab which will add File Edit View Favorites Tools and
Help
Click on the tools at the
bottom of the drop down list will be internet options or
Click start control panel
internet options you will see a home page box To Create Page Tabs type
each adress on its own line
(type in google.com) or your preferred home page and browser
below that will be change
search defaults click on settings you will see all search Providers
Toolbar extensions and
Accelerators you have
have
if don't need any of them you can disable or remove them
Cant get in to my computer lost my password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:Ctrl+Alt+Delete won't work, you have to use some
windows password reset tool. I recommend
Windows Password Reset.
Resource:
http://www.windowspasswordreset.net
How to download and install skype on my windows 7
To install Skype,
download the latest version from the Skype website. Do not download Skype from anywhere else.
The Skype install file is about 1MB in size. When you run the install
file, the installer will download the Skype application (about 20MB) in
the background. If your internet connection drops while this is
happening, the installer will resume the download as soon as
connectivity is restored.
If you do not wish to use the light installer, download the
full installer (around 22MB).The system requirements for running Skype on different operating systems are described below. Please ensure that your system meets these requirements, and that you have the equipment you need, before downloading the latest version of Skype.Version : Windows XP / Windows Vista / Windows 7 (32-bit and 64-bit versions supported)Processor : At least 1GHz RAM : At least 256 MBAdditional software DirectX v9.0 or aboveHope this helps (remember to rating this answer and leave us a testimonial commetn).
How do i install skype to my desktop
I have read many issues and conflicts of skype on vista os.Just
don't upgrade to Vista. It's confusing, the security thing is really annoying.Format it and use XP OS. Thanks!!!
How do I get rid of a abode flash player google
Adobe flash player and google toolbar are 2 different things. I don't think you want to get rid of adobe flash player because it is needed to correctly display many web pages but you can get rid of google toolbar.
To do that, go to start, control panel, and under programs, click uninstall programs. Scroll down until you see google toolbar. Click on google toolbar to highlight it. On the top of the window, click uninstall. Follow the wizard until it says the program was successfully uninstalled. You may need to restart your computer once the program is uninstalled.
Let me know if this solves your problem.
My Vista home premium has crashed & is asking
The product key as you probably know, is printed on the Windows Label underside of your notebook.
Unfortunately, if someone has taken the number and registered a fresh machine with it, it has been stolen and will not let you use it again.
It may be worth contacting Microsoft and send them a photo of the label as proof. Otherwise you are stuck with having to purchase a fresh system from Microsoft.
Hope that helps.
Vista sp1 causes my computer to crash
If Acer supports Vista on that model they will have a patch to fix this problem. If it came with XP they most likely don't support Vista. I would go back to XP on it if that is the case.
My Acer (windows vista)l aptop has gone widescreen
The best way to resolve the issue is to boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select
"Safemode" from the Advance boot menu. Once you are on the computer Desktop, click Start menu> Control Panel> Appreance and Personalization> Personalization> Display Settings>
Under "REsolution" move the poitner to "Low", click OK and restart the computer. It should take care of the issue.
I have a window xp laptop fujitsu siemens
in the bottom right of your screen you will have an icon of your touch bad conttroller open it and change the setting if not open your control panel and then open you mouse you will find the sensitivity change it as you want
