20 Most Recent Acer Aspire 5720 Notebook Questions & Answers
How do I download iTunes?
type in google "download itunes' its as easy as that
12/27/2015 8:08:52 AM • Acer Aspire 5720... • Answered on Dec 27, 2015
Why isn't my Acer Aspire 5720 mouse pad responding?
do you have disassembly it????? try to reconnect cables in right position .
4/9/2015 12:13:31 PM • Acer Aspire 5720... • Answered on Apr 09, 2015
Operating systhem not found
Check your hard disk, it may be shot. I also check out partitions with a bootable partition disk.
2/1/2014 4:10:18 AM • Acer Aspire 5720... • Answered on Feb 01, 2014
Error 0x00000005
VIRUS SOZ
12/10/2013 1:47:43 AM • Acer Aspire 5720... • Answered on Dec 10, 2013
2answers
Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
10/23/2013 7:53:24 PM • Acer Aspire 5720... • Answered on Oct 23, 2013
2answers
I have an Acer Aspire 5720Z. The microphone will
The fact that your internal mic works and then goes out, is more likelly a drivers problem.
I would run your device manager with all external devices disconnected and look for flags.
If you have a device problem, it will show up here.
Remove and flags and allow your operating system to reload drivers after a reboot.
If this has not fixed your problem, try to boot into safe mode and check your internal sound devices their. Sounds like a driver conflect.
Hope this has helped,
9/26/2013 9:57:06 AM • Acer Aspire 5720... • Answered on Sep 26, 2013
Boot mgr missing
Sorry, sounds like you going to need to reinstall windows
2/11/2013 12:38:13 AM • Acer Aspire 5720... • Answered on Feb 11, 2013
Forgotten hdd password
Your only option is to wipe it. Sorry
2/11/2013 12:32:55 AM • Acer Aspire 5720... • Answered on Feb 11, 2013
2answers
Do acer 5720 have tv card
The TV card is an option. Search for the following: Acer Aspire 5720 AverMedia TV Tuner Driver
1/29/2013 1:28:38 AM • Acer Aspire 5720... • Answered on Jan 29, 2013
My aspire 5430 does not start
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
10/10/2012 9:21:50 AM • Acer Aspire 5720... • Answered on Oct 10, 2012
2answers
How do you restore an acer 5738 to its factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop. Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files. Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue. Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings. Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at http://www.vtechsquad.com/acer-support/
9/25/2012 6:30:52 AM • Acer Aspire 5720... • Answered on Sep 25, 2012
What is the right resoultion for laptop
Try starting with a screen resolution od 1024 X 768 and you may wish to increase it further.
8/24/2012 5:30:36 PM • Acer Aspire 5720... • Answered on Aug 24, 2012
CHARNIERRE DE SUPPORT
Mettez un peu de lubrifiant en poudre de graphite sur la charniere pour l'assouplir.
8/19/2012 12:47:58 PM • Acer Aspire 5720... • Answered on Aug 19, 2012
Miss acer aspire 5720z log in password
If you have a second user account on the computer log on with that account and then delete the user account for wich you forgot the password for. Sounds crazy I know but i have done it several times myself.
Joe
6/18/2012 6:49:09 AM • Acer Aspire 5720... • Answered on Jun 18, 2012
2answers
Need administator password for Acer 5720z notebook
Reset Acer windows password, I recommend you use Windows Password Reset , I have used it to crack my acer windows password few days ago,it is easy and safe.Here how it work:Step1:Download and install Windows Password Reset .Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.Step3:Put in your newly created CD and remove your Windows Password.You can have a try.
6/14/2012 3:58:51 AM • Acer Aspire 5720... • Answered on Jun 14, 2012
Acer Aspire 5720 - was on the internet when display fuzzed out and then turned black, now have no display only fuzzy black/grey screen. Can you tell me what the problem is?
Unplug your laptop and remove the battery from it, and wait 5 minutes, that should drain any remaining power from the laptop, re-attach the battery and the power cord, and turn it on. It should work fine again.if not, let me know.
6/11/2012 6:33:44 PM • Acer Aspire 5720... • Answered on Jun 11, 2012
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and BatteryB) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.There are four Philips head screws to remove in the cover, before the cover can be removed.1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove. D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.(Optical Disk Drive. The DVD drive)This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
6/3/2012 11:34:23 AM • Acer Aspire 5720... • Answered on Jun 03, 2012
Acer Aspire 5720 Notebook Logo
Popular Tags
120 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer 5720 tv card
  • Computers & Internet
