20 Most Recent Dell XPS M1330 Notebook Questions & Answers
LCD cable is loose inside PC, need to be opened up and reseated or replaced, if under warranty call DELL support to request onsite tech to repair.
Dell XPS M1330... | Answered on Oct 30, 2017
wrong jumper settings on hard drives
Dell XPS M1330... | Answered on Aug 04, 2017
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Dell XPS M1330... | Answered on Jul 15, 2017
Search Results
Latest Vista Update stuck in Stage 3/restart loop - Microsoft ...
https://answers.microsoft.com/...update/...update-stuck...3restart-loop/2f70b13c-9db4-...
Jul 26, 2009 - I have Vista Business system on a Toshiba notebook, latest Service Pack and with allupdates. ... I just booted it up to find the Stage 3 page of a Windows update. ... Have tried using F8 to get last good installation, and to stop auto restart, without success, it just keeps returning to ..
Dell XPS M1330... | Answered on Mar 21, 2017
For yahoo mail you can click on options in the upper right hand corner then click mail options then press filters then add filter. Then what you can do is name the filter and put the senders email address in the sender part of the form and you might want to check the sender match case box. Also if you wish so you can know when you get mail from that specific person you can also have it go to a folder with whatever you want to name it. Just click down menu next to move to folder and press new folder. Then at the top of the page press save changes and then type in the folder name. Then you won't have to worry about it going to the spam folder anymore. If you need more info just post a comment and I will respond as soon as I get the comment.
Dell XPS M1330... | Answered on Feb 24, 2017
as you would normally do....unfortunately your make/model machine is well known for faulty optical drive. If you purchased it recently.....and you cannot get it to read the disk......contact the suppler if you have any warranty left.
There are numerous rreports of this fault online I am afraid
Dell XPS M1330... | Answered on Jul 20, 2015
did you try using the original disk that came with the laptop and use it to repair computer. or uncorrupted copy
could also be a virus
Dell XPS M1330... | Answered on Jul 15, 2015
You may follow the steps mentioned below to restore the Dell XPS M1330 to its factory default:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
9 You will need to run Windows Update as well as Live Update for your virus protection as these will be seriously out of date.
Hope this helps..
Dell XPS M1330... | Answered on Feb 19, 2015
The best way to clean under they keyboard is with a can of air, like "Dust Off". If you are wanting to clean quite specifically under the keyboard, (circuit board and all) you will need to start by removing the battery from the computer. Then remove the plastic tab below uncovering the RAM. When you do that you will see 3 screws right below the battery and then 2 under the plate you just removed labled with a keyboard picture. when you remove all of these screws flip the computer back over and open the screen. Using a small flathead screwdriver gently pull up on the edges of the keyboard until it releases. Be careful once its released as there is a ribbon cable connecting the keyboard to your laptops motherboard. You should now be able to clean both under the keys of your keyboard and under the keyboard itself.
Dell XPS M1330... | Answered on Jun 22, 2014
posting the stop error code and what you are doing when error occurs would be helpful. If you are getting blue screens and have pixelation of video, artifacting or other Video weirdness, then you may have a defective motherboard. If you have video corruption, and the system is in warranty or if the warranty has expired in the past year, contact Dell tech support for a motherboard replacement.
Dell XPS M1330... | Answered on Jun 21, 2014
hi
first you scan the virus, remove temporary files;
second has verrificar the HDD sector has bed, if you have to back up the Player info and do the restore on the new HDD.
Dell XPS M1330... | Answered on Jan 31, 2014
What version of windows?
click
Dell XPS M1330... | Answered on Nov 02, 2013
You can download the latest driver from your pc`s manugacturer website and re-install it. Hopefull this shall solve your problem.
Dell XPS M1330... | Answered on Oct 21, 2013
Dell XPS M1330 Notebook Logo
243 questions posted
Popular Products
Ekse
Clive
Clive
View Most Popular
XPS Dell
  • XPS Dell
Most Popular Question
burn dvd
  • Computers & Internet
