20 Most Recent
Dell Latitude D630 Intel Core 2 Duo T7250 2M L2 Cache, 800MHz Dual Core 80GB/512... PC Notebook Questions & Answers
Bluetooth signal is cutting out
I'm assuming that you have Windows 7 Home installed:
Click on: START
Right click:: MY COMPUTER
Click on : DERVICE MANAGER (in the upper left of the window)
Scroll Down to: Bluetooth
Double Click: Bluetooth
Right Click: Properties
Then you want to look for any yellow notifications (like a caution sign on the highway) then click on that and then click on Trouble Shoot , follow the directions.
Right Click
Dell latitude E/6400 blank screen worked yesterday
run the dell diagnostic by turning the laptop on and tapping F12 key when you see the Dell logo
keep pressing F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will beep and display colored bars then ask your if the colored bars were displayed. to press Y for yes and N for no
this test the graphics/video chip on the computer to see if the hardware is working.
You can also connect it to an external monitor like a monitor that comes with a pc.Then press and hold the "FN" key and press the F8 (CRT/LCD) key to toggle the external monitor. if the image is displayed in the monitor then it can be a lcd screen or lcd inverter in laptop.
hope that helps
How to back up d630 BIOS to CD
The BIOS is stored on a ship inside your computer and cannot be downloaded and copied over to something else. Please keep in mind that your BIOS is what boots up your computer and your OS is usually Windows. BIOS cannot be backed up but your OS can.
If you wish to backup your OS there are many ways to do that. If you have windows 7, 8, or 8.1 Windows already has a built in backup program that you can run. If you are on Windows XP or Vista then you will have to download and run your own backup software.
Casper is a good backup solution for XP http://www.fssdev.com/products/casperxp/
Dell code 2000-0148
It could be the motherboard, but it is more likely to be a hard drive. Back up anything you need as soon as possible and replace the drive and re-install the operating system(Windows)
Adapter not recognized
You should have purchased an adapter from Dell. The one you have have now may have damaged your motherboard of the laptop and that is why you are are getting that error message.
