20 Most Recent
Dell Laptop InspironTM 1501 PC Notebook Questions & Answers
Disable sticky keys
Just click or double the keyboard icon on you lower-right of your desktop and unchecked the box. or click the arrow color white same location to see you keyboard icon.
My computer sound not coming is that was software
Dear Pradeep
Welcome to Fixya.
This is problem deffinately due to a sound driver application problem. So you have to locate correct driver from dell recovery media or from their website,then reinstall the driver. It will deffinately solve your problem
Best Regards
Chandrashekhar bhat
My Lexmark X5070 Printer is connected to my
The printer you want use, just given a print to that printer will tuned into online, if it not happed then use these two methods:-
1. set as default printer from control panel
2. re-install the printer after un-installation
Which is better processor between amd athelon ,sempron, turion 64
Hello rakeshmedita,
The Turion is more of a mobile processor meant for laptops since it uses less power while the athlon is for desktops and uses a bit more power. The Turion might edge out the Athlon on performance but will beat the pants off it in power consumption. The sempron is a low-cost processor meant for entry level desktops. So, to answer your question it goes Turion, Athlon, Sempron.
Hope this helps, if so please leave some positive feedback. Thanks.
Will not process DVD -R, +R, -RW, +RW discs
You need to get a program such as Nero or Roxio that can burn them. Once you do this, you'll be able to write content on them for use in other computers.
www.nero.com for a free demo of Nero 9
Run dell error
Since this is such an old machine I would imagine there are a lot of unnecessary programs running in the background and starting with windows. I would say the quickest solution would be to back up any data you want to keep and then reformat and reinstall. If you do not wish to do that there are some other steps you can take. First go into the control panel and then add/remove programs. Go through the list and uninstall everything you don't need/want. Secondly, click start then click run and type in "msconfig" without the quotation marks. Click on the start up tab and uncheck everything you don't need to have starting with windows. I would also run your spyware/adware scanners and run your anti-virus. Lastly, I would defrag your hard drive.
Reformat PC
once you format and get to the screen where you're prompted to install xp, just make sure that you type a number that's half the size of your drive. format the first, do the installation and don't worry about the second one until needed.
when installing the second O/S, just pick the remaining space that's probably not partitioned, partition it, format and install.
It should take care of the boot.ini entries automatically for ya.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
