20 Most Recent
Kenwood KDC-W3534A CD Player Questions & Answers
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
6/12/2021 7:47:09 AM •
Kenwood...
Answered
on Jun 12, 2021
How to fit the little yellow wire
Yellow from Connector A needs to be connected to a constant (unswitched) 12V+ source. Depending on the make and model of your vehicle, and whether or not you are using a vehicle-specific wiring harness, you may be able to simply connect the spade connectors or you may need to tap into the vehicle wiring.
Here's the manual. The wiring color code and diagram is on page 25.
http://manual.kenwood.com/files/B64-3488-00.pdf
3/29/2011 6:43:51 PM •
Kenwood...
Answered
on Mar 29, 2011
Stereo says protect
you will need to input the security code. this happens if you unplug your car battery. or lost power.
3/19/2011 4:44:17 PM •
Kenwood...
Answered
on Mar 19, 2011
My KDC W-3044 is shown Protect. what should i
If it is in protect mode then you have a short in your system. A blown speaker will cause it to go into protect mode, also if there are any power supply problems like a loose ground wire or a sketchy connection at the wiring harness it will also trip. My advice is pull the deck check power supply and ground and wiring harness, if it doesnt go away you know its the speakers.It may however need to reset and you will need to unplug the wire bundle from the deck for a moment before getting into the messing with the speakers or wires. Hopefully that cures it so test it and see. Okay if that didnt fix it then you likely have a blown speaker somewhere in the vehicle so get that replaced and rock on.
12/11/2010 7:02:46 PM •
Kenwood...
Answered
on Dec 11, 2010
Need an instruction manual for
You can download and print the instruction manual in PDF format by clicking this
link.
Please note:
Adobe PDF Reader is required to view this manual.
Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using
FixYa.
9/10/2010 10:06:03 AM •
Kenwood...
Answered
on Sep 10, 2010
