20 Most Recent
Kenwood KDC-138 FM / AM Receiver Questions & Answers
Kenwood kdc-138 wire color code
I'm not familiar with the color code of this model but I have a copy of the service manual which may help you regarding on the pin-out of the harness. Let me know your email add and I will send you the copy.
Regards,
Jdvillanueva
Subwoofer settng
Hold src button for two seconds and they access the menu. Radio has to be in stand by mode
What is the blue and yellow wire on the wire harness for the kenwood kdc-138?
According to any wiring diagrams I have looked at for the radio in your vehicle (both the premium and base systems), the only wire that I see that could get pretty much anyone confused unless they know is a dimmer wire coming from your headlamp switch. The only reason I cannot be 100 percent sure is because according to the wiring diagrams it is a black and yellow wire but I don't see any other wire with yellow that could cause a question. To be sure you can always check at the connector on the headlamp switch and check for continuity but if I were a betting man I would put my money on this. I went on and gave you the wiring diagram for the base system (without an amp). Not sure how well you can see anything due to a size limit on pictures but I hope I was able to help.
