20 Most Recent
Frigidaire GLTF2940E Front Load Washer Questions & Answers
Frigidaire front load washer
E59 code means you need a new circuit board and Frigidaire knows it's a problem, but will only step up to repair if you demand it. we're on our second circuit board in 2 years!
Washer wont fill
Fault with the inlet valve, it caould have failed or clogged with dirt. Also if there is no power from the controller unit then the inlet will not workcheck this link for tips:
inlet valve
Keep get an e10 reading on all wah cycles
The fill time is taking too long as what error code E10 pertains to. The
problem is either the water supply is not turned on, the water valves
are not working or the screens are blocked, the pressure switch is not
tripping, or the water flow meter, is there's any, is not working. Check
if water is actually coming in or not.
Water Not Coming In
The
problem is with the water supply or the water valves. Make sure the
water supply is open and the water valve screens are clear. If water
supply is on and the screens are clear, measure the voltage across the
water valve solenoid which must be around 120VAC when the water valves
must turn on. If there's voltage, the problem is with the water valves,
replace it. If there's none, the problem is with the timer/control or
the wire harness connecting the water valves. Check the wires and if
there's no problem, the timer/control is fault and needs to be replaced.
Water Coming In
The
problem is with the pressure switch not tripping. Check the pressure hose attached to the
pressure switch for kinks and air leaks as these can prevent pressure
build-up that should trip the switch from empty to full position. Also
detach the pressure hose then blow air forcefully down through to clear
any possible clogs. Do the same with the pressure switch inlet to
possible free welded or stuck contacts. Replace the pressure switch if
there are no apparent problem with the pressure hose and its connections
to both the switch and the bottom of the tub.
No high speed spin, display
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Washer will not spin goes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
I tried to wash a
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Frigidaire GLTF2940ES0 Front Load Washer
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
When I turn the program control to normal wash and
First thing to try is unplug the unit for 20 min. then try again. If it still acts the same it is most probably either the interface or the electronic control. It will take a technician to tell the difference.
I have a fridgidaire front loader washing machine
Welcome to FixYa
It sounds like (based on your initial description) the unit is detecting an incomplete drain or an unlocked door, hence the control will not initiate a hi-speed spin.
I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
If it does indeed drain fine, then here's the next place I'd direct you to investigate.
**Unplug the unit from the wall first...safety first**
It will require you to visually inspect the control board, thus needing to remove the top panel by way of taking out the screws at the back and sliding the panel back and up.
What to look for specifically is the wires with the green connector fastened to the board securely...I've seen a few vibrate loose thus preventing the unit from spinning, i.e.
If loose push it all the way in until it cannot be pulled out with a slight tug ( there are clasp's on the connector but I suspect sometimes they aren't secure when leaving the factory...just my suspicion )
If these things can be ruled out, then it is quite likely the door switch, so here's how to change/access the latch assembly...
**The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
The washer works oke ,but it does notspin after
Welcome to FixYa.
Based on what you've described, and provided the unit is draining ( and I mean the drum is clear of water aside from the items being soaking wet )...you likely need a door lock/switch assembly.
P.S.
Regards,
Macmarkus :)
EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
E20 error code on gltf2940
The problem is with the pump, or drain hoses.
This caused because there are some things like coins dust blocking the
water path.Clean the pump and drain pipe ,this will solve the problem
Thank You
No spin cycle, stopped running
Hello, sounds like this is going to be a pump issue, take the lower panel on the front off the machine, there you should see something that resembles a gas cap like on your car. It will be located some where near your pump...Unscrew this cap making sure you have some towels handy to mop up the water that runs out. Once you have pulled out the cap attached you should find a filter cage. You will likely find a bunch of debris,coins,lint and other stuff blocking the pump. Replace this cap or filter and plug machine in and try again, You should be good to go. If this does not fix the problem you are going to need to replace the pump.
p.s not sure why you are looking to replace the door latch since you mention the machine is not spinning. The door latch has nothing to do with the spin other then locking.
Good Luck!! if you have any toher questions or concerns please feel free to comment again. Mike
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Frigidaire gltf2940es3 dont go into spin
put in door lock /switch fixed problem the switch sets behind the rubber seal a thin wire clamp around the seal with a spring at the bottom frount holds the seal in place realy is no problem to change
No water coming to washer
It can be a few things.
Simple one first. Where your hose connects to the machine is a filter in eache hose. Clean those as they will plug up and cause this same situation.
2nd: If that does not help it can be 2 things.
Pressure switch ( stuck in full position)
or water valves in the dispenser area.
Follow
LINK to get idea on parts and drawing of the machines. Just click on the sub components
