20 Most Recent Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Questions & Answers
0answers
Driver
no detecta mi disco
3/7/2014 9:45:39 AM • Trekstor... • Answered on Mar 07, 2014
Windows 8 wont see my Trek Stor hard drive
See if your product is listed at the official manufacturer site http://www.trekstor.co.uk/downloads-en.html , or contact them there. Be very careful with other 'third party' sites that offer drivers; many are unscrupulous sites that will give you a 'driver' that contains spyware, or makes things even worse.
12/2/2013 7:36:14 AM • Trekstor... • Answered on Dec 02, 2013
I have a Trekstor 640m GB externaal hard drive. at
You might want to check out this link from Microsoft. See if this might help you:
http://support.microsoft.com/kb/871233
6/8/2013 4:57:53 AM • Trekstor... • Answered on Jun 08, 2013
Trekstor external hard drive (DSMNU-S-JM-a) is on (blue light) but the device no longer shows up on the computer. Can't be accessed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.External Hard Drive Recovery Software
3/10/2013 1:54:12 PM • Trekstor... • Answered on Mar 10, 2013
Goggle Chrome has stopped working
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimak To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help click on the tools at the bottom of the drop down list will be internet options or click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.chrome) or your preferred home page and browser below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection hope this helps
e sure its enabledPci device arrows key scroll to nstalled
11/10/2012 7:35:28 AM • Trekstor... • Answered on Nov 10, 2012
The HD start with blincking
Sorry, what you hear is the so-called click of death - the reading head is no longer capable of reading the data on the disk. This in unfixable and all the data on the disk is lost.
7/15/2012 11:44:09 AM • Trekstor... • Answered on Jul 15, 2012
3answers
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
6/15/2012 4:20:10 AM • Trekstor... • Answered on Jun 15, 2012
2answers
My trekstor hard drive was fine and we haven't
The hard disk inside your external unit has died. If you want to keep the case it can be replaced with a standard SATA disk.
3/24/2012 12:21:05 PM • Trekstor... • Answered on Mar 24, 2012
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
1/2/2012 10:08:26 PM • Trekstor... • Answered on Jan 02, 2012
My computer does not reconize my Trekstor
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or if you can see your usb but its not workingports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seatedif this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
10/4/2011 1:31:18 AM • Trekstor... • Answered on Oct 04, 2011
Hdd not recongnized and unable t open.accesible
Hi ,
It sounds like you need to format the harddrive , then you will be able to use it .......
if you need more help , let me know .................Roy
8/8/2011 5:57:27 AM • Trekstor... • Answered on Aug 08, 2011
Need software because my computer
Improve the Fixya.com experience for everyone by voting!
Click on the following link for the official Trekstor DataStation Maxi mu site: Trekstar DataStation
If that official site doesn't provide you with the required driver, continue reading.
Click on the following link for the largest FREE driver database on the internet. Driver Download
All the best,
Ben
7/15/2011 10:26:08 PM • Trekstor... • Answered on Jul 15, 2011
0answers
2answers
Trekstor datastation maxim.u 5oo bg
Yes, there may be ways you can try put hard drive in the ziplock bag and put it in the freezer and wait for an hour. Take it out and try it. If it works, try to move your data and quickly as you can. It worked for me before. If disk contains very important data, and you have tried the above step but didn't work, you may want to spend $49.00 for the recovery software. This software works for me more than 90% of the time (you don't have to spend more 2K to send your disk to professional data recovery stores). Here is the link. I have used their product before and it worked, you can call them for support too after purchase the product. http://www.stellarinfo.com/disk-recovery.htm No one can guarantee 100% that your hard drive can be restored including my recommendation . It really depends on bad the damage to your disk is. You just have to take a chance. Good luck. I hope you don't reject my solution. Thanks
5/20/2011 3:41:12 AM • Trekstor... • Answered on May 20, 2011
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
53 questions posted
Top Trekstor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DataStation Trekstor
  • DataStation Trekstor
Most Popular Question
windows 8 wont see trek stor hard drive
  • Computers & Internet
