20 Most Recent
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Questions & Answers
Buffalo external hard drive not recognised on PC
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
- The USB cable between the drive and the computer may be damaged.
- The circuit board which connects your drive to the interface of the external may be blown.
- The power supply (if applicable) may have a blown transformer.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
2/9/2014 4:57:00 AM •
Buffalo...
Answered
on Feb 09, 2014
My 250GB Buffalo removable hard drive has recently
you probly have a bad hard drive or a corrupted hard drive or a corrupted file on the hard drive that causes the hard drive to crash and if this is the case then there is no help for your data
10/31/2012 12:38:49 PM •
Buffalo...
Answered
on Oct 31, 2012
Hello....I recently dropped my Buffalo
It is always possible to recover the data as long as you have the budget for it. If you take it into a shop they most likely will try to take the drive out of the case and hook it up to a computer using an adapter to see if that will work. If this does not resolve it you will have to send it into a specialty recovery shop.
3/24/2011 6:14:15 PM •
Buffalo...
Answered
on Mar 24, 2011
Total space problem
The windows use some space for space addresing but not that much
It shoves 149 GB because manufacterers use the terms gigabyte in metric (base ten) way.
IT means 160 GB = 160 * 1000 MB = 160 000 * 1000 KB= 160 000 000 * 1000 Bytes
when you convert that in Gigabyte that computer use (1GB = 1024MB, 1MB = 1024 KB, 1 KB = 1024 Bytes) you get:
160 000 000 000 Bytes = 160 000 000 000 /1024 KB = 156250000 / 1024 MB = 152587,890625 / 1024 GB = 149,011 GB
6/19/2010 10:12:50 AM •
Buffalo...
Answered
on Jun 19, 2010
Can i make my portable hard drive as internal hard drive?
you boot from it but putting inside means taking it apart finding the connections that will adapt it to your pc or whatever but it is possible
booting from it would require simply installing an os onto the drive instead of your c: drive, just keep in mind you will have to change your bios to boot from the appropriate drive
6/2/2010 2:42:05 PM •
Buffalo...
Answered
on Jun 02, 2010
I have a 250GB Buffalo Turbo USB Hardrive. Until
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
10/30/2009 2:17:29 PM •
Buffalo...
Answered
on Oct 30, 2009
