20 Most Recent LaCie 160GB Little Disk USB2/FW400 160 GB Hard Drive Questions & Answers
I have a LaCie 160GB Little Disk uses a 5V power
Unfortunately this is a great mistake to have plugged in the higher voltage . Since you are experiencing heat on the unit, it will be good to see the secction that is heating up. If you are able to open the set and look into there is a possibility that the regulator could have failed. If so check the short in this section and replace the driver. But if the processor IC is heating up we are in for serious fault.Since if the board has failed then we are in the mercy of the dealer who controls the spare. Maybe if the cost is so high you must check the price of a new one and try to transfer the files. hope you try this out. Good day
8/19/2010 2:38:24 PM • LaCie 160GB... • Answered on Aug 19, 2010
The hard drive icon does not appear on my desktop
open windows explorer you can see find it there
8/18/2010 7:35:18 PM • LaCie 160GB... • Answered on Aug 18, 2010
The harddrive wont power up witout the power cable
You need the power from the 2 USB ports in order for the Drive to have enough Power.
Try moving the USB Ports to another Port or Flip Flop the 2 USB Cables.
Another option is to uninstall the unknown device. Remove the USB Cables, Uninstall Shut Down, Re-Start.
NOTE: Certain Ports on your System are USB 2.0 and some are not. Try to use the 2.0 port listed in the Manual... it will be faster and may carry the Power.
1/7/2010 3:31:07 PM • LaCie 160GB... • Answered on Jan 07, 2010
I was copying a large amount of data - 65GB from
Your copy process was interrupted so you'll need to perform the entire operation again to ensure you have all of your data and to also make sure none of it is corrupted.
7/10/2009 11:49:55 PM • LaCie 160GB... • Answered on Jul 10, 2009
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
  1. Disconnect all cables from the device.
  2. Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
  3. Wait for the device to restart and initialize. This may take several minutes.
  4. Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
2/11/2023 5:07:18 AM • LaCie Computers... • Answered on Feb 11, 2023
My LaCie Porsche Design 8TB Hard Drive wont receive power
Please check the link https://www.youtube.com/watch?v=VrhHzRDaXik
12/8/2022 5:19:01 PM • LaCie Computers... • Answered on Dec 08, 2022
2answers
I have problem with disk LACIE. He is write protection
Check the data recovery programme used for an idea or start again now you have your data back by re initialising and formatting the drive as a new one.
6/27/2022 7:20:03 PM • LaCie Computers... • Answered on Jun 27, 2022
I have the LaCie Porsche 500Gb external USB hard drive. is computer is unuble to detected the hard drive .show PnP problem .how to fix it?
Depending on your OS, use your disc utility and see if it has been initialised or not. If not initialise it and then you can format and use it as normal.
6/27/2022 7:19:12 PM • LaCie Computers... • Answered on Jun 27, 2022
Forgot password of lacie rugged hard drive
Did you get it fix ? Have the same drive and forget the password!! Need help
4/25/2022 5:11:24 PM • LaCie Computers... • Answered on Apr 25, 2022
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
12/2/2021 10:39:59 AM • LaCie Computers... • Answered on Dec 02, 2021
I for got me password I don't even remember setting one up Lacie rugu3m2
Just an idea. When you set pass words or any important information write all information in a note book and keep it in a drawer someplace where you will not lose it. When things change write the new ones down and cross out the old ones. I save a lot of head aches that way.
1/22/2019 9:12:10 PM • LaCie Computers... • Answered on Jan 22, 2019
Hello, I have a LaCie D2 525 Super Writemaster. Stopped reading CD, slowly flashing it'sLED. No image on desktop. Eject button doesn't react and paperclip insertion activates eject but tray is stuck.
Pushing in the paperclip should unlock it, but if still jammed, may have to wreck drive by pulling off front of drive drawer thing. Maybe try putty knife to push cd down some of that's holding it from opening.
1/22/2019 4:25:39 PM • LaCie Computers... • Answered on Jan 22, 2019
I have a Lacie external drive when the power plug connection on the circuit board broke off. Can the circuit board be repaired or replaced?
Replace perhaps, but repair is most difficult. The electronics are miniature and it takes special tools to do repairs.
1/2/2019 7:13:50 PM • LaCie Computers... • Answered on Jan 02, 2019
Can I remove the disc from a LaCie 300770 250 GB drive and try it in another drive? The drive is not working, so I hope the disc is ok.
Two ways this can go. If you are talking about the entire hard drive pulling it out and plugging the whole drive into another pc. Then you're fine If you are talking about disassembling the hard drive and moving the disks inside. This is not something you can do. This is what you will need. 1) a certified clean room surgical grade 2) tape 3) A matching drive/ hd board down to revision number 4) presision screw tools. 5) patience. Or you will need to contact a professional data recover company.
12/29/2018 9:24:31 PM • LaCie Computers... • Answered on Dec 29, 2018
3answers
Lacie n2870 driver
You need a new driver for sure, and here you can find it driverupdate us. This tool usually keep my drivers up to date (perfectly for now) take a look
9/14/2018 12:27:06 PM • LaCie Computers... • Answered on Sep 14, 2018
LaCie 160GB Little Disk USB2/FW400 160 GB Hard Drive Logo
16 questions posted
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LaCie Computers & Internet
Most Popular Question
harddrive wont power up witout power
  • Computers & Internet
