20 Most Recent
Frigidaire FGFB75D Gas Kitchen Range Questions & Answers
I wanted to clean the
If it's a standing pilot (on all the time), rather than a spark igniter, just hold a match in front of the pilot orifice and it should light.
The electronic display went out on my gas range so
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
I hear the stove going
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
11/24/2010 10:18:23 PM •
Frigidaire...
Answered
on Nov 24, 2010
When tryingt to turn oven
Hi
Thanks for using FixYa. Error F3 in your range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
My frigidaire gas stove will not heat the "bake" part
If the bake
ignitor comes on - check the
amperage on
the bake ignitor wires when it's on. If the ignitor is a round style -
amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If
less
than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528,
WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020,
5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if
you can splice the wires.
Gas burner wont come on
Is the gas shut-off on? (If the problem is with all burners this is the first place to check.) Usually the shut-off is at the back of the unit and you can reach it after removing the bottom storage drawer. Make sure the burner parts are put together properly (some sealed burner units only fit one way). Check that there are no clogs in the burner slits. The clicking is the ignitor trying to ignite the gas, btw.
Additional problems are recommended for professionals. However you can look for a clogged orifice when you disassemble the burner for cleaning.
I hope this helps.
(I don't know of any range that has a separate burner shut-off (just oven shut-offs) but you might check your range.)
F31 error code after self-cleaning cycle
Possibly the temperature probe, check the connection and the wiring to it. These ovens have very badly stamped metal inside that will cut through wiring very easily. Temp probe may be bad as well.
Only the burners on my Frigidaire Model No.
Your pilot has an electrical spark that ignites each burner and your oven as well. It may have taken a hit. But that may be the only thing that you have to replace. You should hear the tick tick ticking when it try's to light and notice the spark. At times if you have lost the ground to the appliace it will not spark either.
