20 Most Recent Frigidaire FEF376 Electric Kitchen Range Questions & Answers
2answers
The oven for my Frigidaire
Check the thermal fuse in the back first.
10/24/2022 2:31:21 PM • Frigidaire... • Answered on Oct 24, 2022
0answers
Code f68 err
Be the first to answer 2/24/2013 4:45:37 AM • Frigidaire... • Posted on Feb 24, 2013Be the first to answer
Oven turns off when door is opened
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/26/2010 1:43:38 PM • Frigidaire... • Answered on Sep 26, 2010
THE DUAL BURNER QUIT.
I would say they got you the wrong part. take them both and make them reorder the correct one
8/19/2010 1:16:37 AM • Frigidaire... • Answered on Aug 19, 2010
My stovetop is locked out - there's a padlock icon
Jan 26, 2010 - by frankegd - Well, after further investigation I found out that simply holding the "Oven light" button for some time will unlock (red padlock) the cooktop...
6/2/2010 1:24:38 AM • Frigidaire... • Answered on Jun 02, 2010
NEITHER OVER ELEMENTS WORK MOD#FEF379ACK
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
4/28/2010 4:11:47 AM • Frigidaire... • Answered on Apr 28, 2010
How do you raise the smooth cooktop on a
the cook top is screwed down with several different screws it does not just lift up.what is the reason you want to raise it up.
1/24/2010 1:43:47 AM • Frigidaire... • Answered on Jan 24, 2010
Some Ovens Control Buttons Don't Work - Frigidaire PGLEF385B
although you cannot see damage / the when the buttons do not respond. its possible that membrain is damaged or the eoc ( clock ) is not able to receive signals from the touch pad .. the clock will have to be replaced . list price for clock is 171.00 and includes membrain ( touchpad) .. hope this will help mm
12/3/2009 4:58:19 AM • Frigidaire... • Answered on Dec 03, 2009
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
1/31/2009 3:40:32 AM • Frigidaire... • Answered on Jan 31, 2009
Left front burner
It has a bad element that needs to be replaced
1/31/2009 3:26:18 AM • Frigidaire... • Answered on Jan 31, 2009
Frigidaire electric range fef336 heating elements not heating
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please leave a rating!
1/31/2009 3:25:06 AM • Frigidaire... • Answered on Jan 31, 2009
4answers
Frigidaire range
Unplug the unit, then manually depress and hold the light switch on the frame of the unit while plugging it back in. The lock should go back into the proper position.
Craig Mac
12/25/2008 9:04:51 PM • Frigidaire... • Answered on Dec 25, 2008
The ESEC lockout feature is
you can unplug the stove and plug it back in that will take the looking position. and in other models, set the oven to clean the oven for 5 minotes, and it will go of and will relace the oven door.
12/6/2008 5:44:25 AM • Frigidaire... • Answered on Dec 06, 2008
Brand New Frigidaire slid in stove
look closely at the control buttons one should also have that same icon on it somewhere, youll need to hold it in for 3-5 secs to unlock the controls. its a child safety feature so the kids wont accidentally turn it on
7/26/2008 9:20:54 PM • Frigidaire... • Answered on Jul 26, 2008
Stove will not turn on
The power connections to your stove or the wiring at the plug are incorrect. The neutral connection is missing (White wire)
6/26/2008 5:13:37 PM • Frigidaire... • Answered on Jun 26, 2008
2answers
Frigidaire PLGFMZ98GCA temperature varys
What was the exact model/ maker of the unit..?
micro
5/28/2008 5:23:26 PM • Frigidaire... • Answered on May 28, 2008
Frigidaire FEF376 Electric Kitchen Range Logo
Popular Tags
44 questions posted
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
oven turns off when door opened
  • Kitchen Ranges
