20 Most Recent Pyramid 4000 Mechanical Time Clock Questions & Answers
USE THE TAPE IN AND OUT DONT FORGET TO TURN ON THE TAPE MON IN FRONT
Pyramid Audio... | Answered on Jun 22, 2017
Hi, yes sure you can. Just be sure when disassembling to make notes where necessary to keep track of where parts go-and when you get to the lamps ( either under or in back of the meters-use a volt/ohm meter to measure to voltage so you know the size to replace them with ie.. a 6 volt or 12volt. be careful when powering on a disassembled unit ( no parts touching each other, touching a metal part of cabinet) and if you want you can wrap some electricians tape around loose or exposed parts for safety. Good luck, I hope this was of some help and thanks for choosing FixYa. Prodzilla
Pyramid Audio... | Answered on Apr 20, 2011
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Pyramid Audio... | Answered on Jul 27, 2009
is the positive cable hooked to the battery or the fuse box and it sounds like a grounding problem
Pyramid Audio... | Answered on Jun 30, 2009
Hello Joseph, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Joseph, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Audio Players &... | Answered 4 hours ago
Hi Ihtisham, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Hola Ihtisham, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Audio Players &... | Answered 13 hours ago
You can view the manule here:
https://www.manualslib.com/manual/192102/Technics-Sl-Mc7.html#product-SLMC4%20-%20COMPACT%20DISC%20CHANGER
(I think they also let you download a PDF of it as well).
Audio Players &... | Answered 14 hours ago
the best video converter i have found is called Xylisoft media converter it has just about every type of video conversion that you could want to do
Audio Players &... | Answered 23 hours ago
If you did not backup your iphone with iTunes or iCloud , the recovery software for iPhone users may help you retrieve the deleted data, you can get them back in few steps.
Tips to Retrieve Deleted Voice Memos on iPhone 6 5S
Audio Players &... | Answered Yesterday
Pyramid 4000 Mechanical Time Clock Logo
5 questions posted
Top Pyramid Audio Players & Recorders Experts
 Grubhead
Grubhead
protojexxx
Dave Cowley
Dave Cowley
Level 1 Expert
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pyramid Audio Players & Recorders
Most Popular Question
replace bulb
  • Audio Players & Recorders
