20 Most Recent
Jeep 2001 Grand Cherokee Limited Questions & Answers
Ran codes on it, crank sensor is bad, how many blots do you have to remove to remove starter to get to the crank sensor?
If it's a 1999-2004 4.0 it's EASY!!!
Go through the firewall under the dash it is EASY!!
Here's how to do it:
1) Remove the plastic bottom panel directly under the gauges. It simply snaps up and out.
2) Locate the 4 10mm bolts that hold the lower plastic panel under the steering column and remove them along with a few phillips head screws as well to free up the panel. Remove.
3) Look behind the console and you will see a small plastic "L" shaped duct that blows air to your feet. Snap it out of its position and remove the phillips screw holding it from under/behind (or cut the plastic flange with a razorknife halfway if the screw is hard to get at - takes a shorty phillips screwdriver. This way you can still snap it back on.)
4) Pull the carpet back and tuck it under the gas pedal.
5) You will see an oval metal plate that the shifter cable runs through as it passes through the firewall. Remove the 2 10mm nuts and pull the plate back.
6) VIOLA! There is the crankshaft position sensor staring you right in the face through the hole in the firewall you have exposed!
7) Insert 11mm socket with extension and remove/replace bolt with ease.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
