20 Most Recent
Sanyo NVM-4050 GPS Receiver Questions & Answers
700p bluetooth set up with Sanyo GPS 4050
I got the pairing code via searching the internet it is 0000 and worked just fine. Now however I get an "Unable to connect message". Sanyo tech support is very hard to get a hold of.,.
MAP UPGRADE FOR SANYO NVM-4050
Unfortunately there is no solution...... I contacted NAVTEQ and I’ve got the following answer:
Hello Jane,
Thank you for contacting NAVTEQ. Currently Sanyo does utilize our map databases however we do not produce nor distribute discs for their systems at this time. For information please contact Sanyo directly at http://sanyoservice.custhelp.com or 800.421.5013; select option 2 then 3.
If you need additional assistance, please send us your feedback by replying to this email or by speaking with one of our agents at the number provided below, Monday through Friday.
Kind regards,
NAVTEQ Customer Service
P.O. Box 1588
Orem, UT 84059
888.628.6277
[email protected]
After that, I called 1800 as suggested and I got the answer I didn’t want to hear:
Sanyo said that “The policy of the company is not to update NVM4050 EVER… the only one to be update is NVM 4370” ….
So, we are stuck with our NVM4050…..
How about everybody that owns a NVM4050 calls them ?!?!?!?!
Can you charge the battery via the USB to a
Yes you can charge your gps using the USB cable, but it will take a few hours to fully charge, If you still have the booklet for the unit under Specs it will say what kind of battery you can pick up at any RadioShack store
Sprint makes these GPS units so I would say get a battery there
Sanyo nvm 4050 problem
I ended up in the same situation and called (800) 421-5013 for help. The gentelman who assisted me said that how the DVD holds the same data
as factory Sanyo 4050 GPS and upgrading has locked your device. To
resolve the discussed issue one have to delete everything (plug-in your
device via USB cable --> My Computer --> Removable disk) and install fresh copy onto your navigation device via that DVD.
Tried it with NO @!@ JOY
No gps signal
Just reset it. Hold the reset button for some good seconds. I hope it works. It did on mine. Good luck :)
Why won't my NVM-4050 start up?
I hope I can help. I had the same problem and I took it back to the store to exchange it and the only thing they did was to reset the GPS. So just press the reset button for 2-3 seconds and see if it works. I hope it does. Good luck. :)
UPDATE MAPS
I have cobra Navone 3000 Gps. I need to update maps on it. Could somene tell me where to get free map download for it please?
How to unlock maps after re-installing them?
I ended up in the same situation and called (800) 421-5013 for help. The gentelman who assisted me said that how the DVD holds the same data as factory Sanyo 4050 GPS and upgrading has locked your device. To resolve the discussed issue one have to delete everything (plug-in your device via USB cable --> My Computer --> Removable disk) and install fresh copy onto your navigation device via that DVD.
Clock reset and cant find satellite
I have had the same problem. I just notice the power switch on the bottom of the unit. I believe if this one is used it will not lose power. The other power button is probably for a standby mode.
Low volume
You can use a FM modulator and hear it fine through your radio, but then you have the problem of no radio to listen to.........Im lost too.
The navigation software
Are you installing the DVD using windows vista? Had the same problem but it worked after installation using windows XP.
Map Update
I got the chance to talk to 1st navteq and they requested that I speak with sanyo, then I got the chance to talk to sanyo customer service who couldn't offer any help other than asking me to wait till December or January when their version of 2009 map upgrade will be made available.There was one interesting revelation I kind of found out on Garmin 770 too; the same addresses could not be plotted or navigated by this also so I think it is a common factor and these are all somewhat new addresses of new developments. My suggestion will be wait till 2009 map upgrade is made available.
mainoo2005
SANYO NVM-4050 Automobile GPS
I had the same problem and what , I did 1st is in my lg shine phone is , I set a diffrent pass code , The on the gps , I reinstalled the back up disk and or reloaded the info for the gps after that do every thing you see on the gps . When you see your main screen got to comunacations turn on bluetooth have it look for your cell phone but use the 0000 code and it work .
Map update for sanyo nvm
Hi whuggins73,
I researched on the most updated map for Sanyo NVM-4370. You can visit this
link for your reference, however you need to purchase this.
For more information you may contact Sanyo directly at http://sanyoservice.custhelp.com or 800.421.5013; select option 2 then 3.
Hope it helps.
Thank you for using Fixya.
3/26/2011 8:39:07 PM •
Sanyo GPS
Answered
on Mar 26, 2011
