NOTE: Please
read the entire post. I have updated this blog entry several times to
reflect changes in both the GPS and Chipset software since I originally
posted this entry. If you have any questions or problems leave a comment
and I will reply back to you. Thanks!
I thought I would take a moment to describe how to fix a problem that
popped up with my GPS Map 60 this weekend in the event it happens to
someone else who might be using this model. I have to tell you, GPS’s
are great tools when you are traveling unfamiliar roads but it’s no fun
at all when they stop working. I know you all have been lectured on the
proper way to shut down your computers by we IT people and you might not
really understand why or even believe that you can corrupt your system
by shutting it down improperly but I am here to tell you, it can happen.
In the process of trying to turn on my GPS’s back light, I shunted the
system and corrupted the software on the chipset. I turned the unit on
and in an attempt to turn on the back light while driving and paying
more attention to the road than the unit, which is a good thing by the
way, I turned off the unit while it was still in the process of booting
up. Instant chipset corruption! You will know when this happens because
your unit will be stuck perpetually at the screen seen in the second
image of this post.
Believe me when I tell you, your GPS will not acquire a satellite no
matter how long you leave it on, no matter how long you leave it off and
then try turning it back on, removing the the batteries or swapping out
the unit’s SD card. The chipset’s software had been corrupted and it
will not work properly until you have reloaded the chipset software. The
easiest way to tell if you have encountered this problem is to check
the software version of your GPS. If the GPS SW version is 0.00, then
you have indeed corrupted the chipset and will need to reload the
software. The third image of this post will show you what version number
I am referring to.
As I have said, in order to get your GPS unit functioning again you
will need to reinstall the chipset software. There are two ways to do
this. You can use the Web Updater program that you probably installed
when you first bought the unit. You will find it under the Garmin menu
from your Start menu. The second way would be to install the chipset
software manually using the the “G” chipset installer. The second method
is the one I used as I kept getting a “Transfer Error” when I tried to
use the Web Updater software. You can download this software directly
from Garmin, if you can find it. I think they want folks to use the Web
Updater software as they aren’t real up front on where to download the
actual installer packages. If you like you can download the software
from this site
here.
NOTE: Here is the latest version of the Chip Set
Firmware, V.3.00. I am providing this as a secondary download as some
have reported to me that the V.3.00 caused their units to shut off
prematurely. Try this version and if you have any problems roll your GPS
back to the V.2.90 software.
I have tested this software and my unit does continue to function
normally so if you want the latest version of the software (GPSMAP 60CSx
Ver. 3.90 as of Mar 30, 2009) for
the GPSMap 60CSX you can download it
here. If you prefer you can download it directly
from
Garmin.
Click
the image to the left to download the GPSMAP 60CSx User Manual
Installing the software in fairly simple.
Connect the GPSMap 60 to your computer using the mini-USB cable that
came with your unit and then run the installer. Refer to your Owner’s
Manual if you need further assistance. All that being said, I love my
GPSMap 60 and this minor bump in the road has not changed my opinion of
the unit. It’s been a great little unit and I fully expect it to remain
so for years to come.
Note: The screens above are not the actual
screens, just approximations I created in PS to give folks a visual. The
actual screens will looks slightly different. I wrote this post to help
others should they have this problem with their GPSMap 60’s as I didn’t
find a lot of clear help on the web when I researched the problem.
Take care.
