20 Most Recent
Westinghouse TX-52F480S 52 in. LCD TV Questions & Answers
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
No picture. Led is amber
Since the Westinghouse symbol shows up on screen, it means that is is unlikely to be a backlight or inverter related issue.. More so since the light stays amber. Did you check the power supply board for any obvious looking faults like swollen at the top/cracked/leaky caps or the 1.5A fuse?
Westinghouse tx-52F480s. flicker, turned into
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
No picture on Westinghouse TX-52F480S.
Hello, I will need a bit more information to help you out on this one. I can troubleshoot with you live on this one just simply email me your contact information to
[email protected] or send me an email and I will give you my contact info.
Hell
I have a 52" Westinghouse
Hi
Thanks for using FixYa. From what
you have described it seems that you
might have a backlight issue with this TV set. It could also be due to the
inverter circuits for the backlights. The inverter is the power
supply source for the backlights. There could also be a screen driver
problem; if it is then you have to change the entire board. All this is only
recommended if you have some kind of expertise for checking the internal
circuitry of the TV as these units have high voltages running even when the set
is switched off.
Please do accept the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Tv won't turn on
Sounds like you are have a bad main board and or power board. You need to contact the TV manufacturer and describe your problem. A lot of these parts have lifetime warranties depending on manufacturer. the service call is comped. If the power board is getting power, you should be able to see a small led light on the power board as well as a click when the unit powers up. If you dont see either of these, looks like your power board is out. hope this helps and good luck, J
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
- Press the power button on your TV to turn it on.
- Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
- Look for the "Reset" option and select it.
- Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
- Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
