20 Most Recent Philips 42PF9431D/37 TV Questions & Answers
0answers
The tv will not turn on anymore-have a blinking
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
5/19/2014 12:25:20 PM • Philips... • Answered on May 19, 2014
How i reset olevia 537 b 11 lcd tv.
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given.
4/15/2014 9:49:33 AM • Philips... • Answered on Apr 15, 2014
0answers
TV code
Be the first to answer 2/6/2014 3:51:22 AM • Philips... • Posted on Feb 06, 2014Be the first to answer
I have a Phillips 50PF732pa/37 plasma tv.
Wish I could help, Dan- by the way, you're posting your problem under "Email Services"; I'd switch catagories.
11/16/2013 10:22:27 PM • Philips... • Answered on Nov 16, 2013
manual
0answers
Hi, I have replaced the power board on my Philips
Hi duarte
I`m going to help you with you tv but first;
Most of the time the power supply is the problem in your set but there are other boards that can cause a Vscan shutdown in the power supply.
There is a large board on the left hand side(from the back) that is called the Ysustain and there is a connector on it with the VS and VA voltages indicated and it comes directly from the power supply.
And on the right hand side there is the Xsustain with the same connectors.
I`d like you to pull them out one a time and try to start the set in between.
See if that makes a difference.
1/19/2013 7:06:43 PM • Philips... • Answered on Jan 19, 2013
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
3/11/2012 7:27:25 AM • Philips... • Answered on Mar 11, 2012
I have a philips 42pf9431d/37 and I have black and green lines on the right side of the tv what is the repair for this
Sorry, unless you know tv's nothing you can do and the fix is very expensive. Basically not worth itHope you have warranty and take it backIt is fairly common to have few "dead" pixels that are not obvious I know this is not the answer you are looking for but all new electronics are made in such a way that it is usually not worth the troubleAfter all this is why they try to sell you extended warranty and if you pass you are stuck and have to buy new
2/6/2012 6:18:48 AM • Philips... • Answered on Feb 06, 2012
Hi I need a base
I need a base or stand for this model. Called Philips and they are no longer making the part. Any suggestions.
8/16/2011 1:07:35 AM • Philips... • Answered on Aug 16, 2011
No picture and red flashing
Check your inputs. If no signal then contact the people who sold it to you. They may send you to the manufacturer for a repair/replacement.
5/4/2011 4:47:01 AM • Philips... • Answered on May 04, 2011
I have the problem philips
Are you saying the tv does not come on when you press the power button as it should? If that is the case - the philips tvs have a known issue with power supplies and if you have experience with electronics I'd say open it up and check the power supply for bad capacitors (bulged/leaking or busted caps) if you have component level experience replace them then try your tv again - ive fixed many philips tvs with this problem.
thanks,
michael
4/18/2011 10:35:15 PM • Philips... • Answered on Apr 18, 2011
2answers
Hello: I have a Philips 42 inch Plasma
Hi, i see all the time these people who think that every fault in a unit, is a capacitor, when it simply is not.
While caps do indeed go "Bad" just replacing them seldom will permanently fix anything. What most miss is that also there is "Other" damage done to "other' even seemingly disconnected componentry.
As said usually we have a fault, the cause, the damage done, and the co-lateral damage ALL must be found and repaired, or the fault will simply reappear, in one form or another.
Accordingly whenever we embark upon a repair the very first place we MUST start, as I tell all my students, is with the Power Supply.
Here we must check ALL voltages, as if they aren't correct here then NOTHING can nor will work correctly anyway.
So to check said supply one simply MUST HAVE a service manual.
4/1/2011 12:39:04 PM • Philips... • Answered on Apr 01, 2011
My plasma TV won't turn on (Phillips model
these tv have a comon short problem w the video &audi bord shield if you remove the cap only it usally fixes this
3/23/2011 1:41:44 AM • Philips... • Answered on Mar 23, 2011
No picture on philips model
You will more than likely need your capacitors replaced. That is the most common problem with these.
3/17/2011 2:40:45 AM • Philips... • Answered on Mar 17, 2011
No picture but i have sound
Step1: Reset power to the TV or DVD or Cable box
go onto step 2 if problem is there
Step2: check all connections
making sure they are all pushed in all the way
go onto step 3 if problem is still there
Step3: Remove one connection at a time and make sure they are going into the right plug
if problem is still there give me more info.
1/23/2011 8:11:27 AM • Philips... • Answered on Jan 23, 2011
I have a Philips 42PF9431D37
I GOT ONE [email protected]
1/7/2011 2:05:10 AM • Philips... • Answered on Jan 07, 2011
Philips 42PF9431D/37 TV Logo
88 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv just clicked as
  • Televison & Video
