Sir when your tv does not operate when you open it and hear a clicking sound the most common part to be check is the power supply. When you remove the back cover of your tv be sure to unplug it then look for bulging capacitor, this bulging capacitor produces a low and unfiltered dc output voltage that causes your unit to malfunction.
If you see this bad capacitor replace it but observe the polarity, and also observe the solder part of the pcb of your power supply look for some loosed, cold solder or dry joints.
If you see this cold solder or loosed solder, resolder this but be sure not to connect separated pin if accidentally solder may cause much damage to the unit, you should have a soldering iron, soldering lead, desoldering pump. try to do this first before replacing the power supply board, power supply board is much expensive. Hope this help good day and best regards.
