20 Most Recent
LG 32LB9D TV Questions & Answers
I have a plasma lg32lb9d.when i plug it in the red
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device,
[Exclude the model number] in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
10/19/2017 5:45:07 AM •
LG 32LB9D TV
Answered
on Oct 19, 2017
I have a LG LB329D
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go.
http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
8/15/2017 2:43:29 PM •
LG 32LB9D TV
Answered
on Aug 15, 2017
LG 32LB9D
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Search the site by type in the number of the SMPS board. The schematic of the power board might be there; and will help you more.
4/21/2017 3:24:05 PM •
LG 32LB9D TV
Answered
on Apr 21, 2017
LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
3/11/2016 4:17:42 AM •
LG 32LB9D TV
Answered
on Mar 11, 2016
No sound
Make sure the speakers are not turned off by looking in the audio menu. also nothing plugged in to headphone jack. Otherwise you will need main board replaced.
7/12/2014 2:15:01 PM •
LG 32LB9D TV
Answered
on Jul 12, 2014
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
12/18/2013 3:44:25 AM •
LG 32LB9D TV
Answered
on Dec 18, 2013
No power
Sounds like a bad power supply.
Find a new power supply, pop it open and change it out. Isn't too hard.
9/10/2012 10:33:14 AM •
LG 32LB9D TV
Answered
on Sep 10, 2012
