20 Most Recent
Kodak EASYSHARE C503 Zoom Digital Camera Questions & Answers
Kodak Z981 -- mode dial issue
I have a Z981 myself. I just set my camera as you did (to "A") but did not experience the issue you mention?
Just to be clear, remember that setting the camera to "A" means "Aperture priority", meaning that you can control the lens aperture (with the "jog dial" on the top of the camera) and the camera will automatically set the shutter speed to create a proper exposure. "A" does NOT mean automatic exposure control. You must use "P" (Programmed) mode to make the camera make all the decisions about shutter speed and lens aperture.
I am including a web link to the User Guide for the Z981. You might want to revisit the Guide to make sure you are using the correct settings for your pictures.
BTW, I like my Z981 quite a bit, especially the zoom. I've taken some great pictures with it.
http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf
How can I switch on memory card?
To unlock the card: Turn off the camera. Remove the card from the camera. Slide the tiny switch (on the side of the card) so that it's not in the Lock position.Aug 25, 2010
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protected
I am haven trouble keep it on and i have change batters in it and it still keep going off
A hanging diaphragm motor !!! or autofocus motor !!! dirt inside ? the first things that will have a time out that will not give a message in a display by simply budget cams
I have no experience in photo digital cameras but i know that a lens will first autofocussing the picture and all, yes all arming course is timed to all electrical components. but if the motor of the focussing can have a problem but also the auto diaphragm motor could be i know for shure there will be the cause of failure to search , 20 years ago i have repaired video camcorders repaired and Samsung have had that same problem ,its a failure in timing shutt-off !! if you have warranty on it GO FOR IT . i think there are no people or hard to find to repair it under 60% of the replacement value. or it is above the replacement value marketing technical sollutions is trade-in rebate !!
