20 Most Recent
Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range Questions & Answers
Heating element does not work in oven
you can unplug the stove and unscrew the bottom heating element and go to a appliance store or home depo and purchase a new one and screw it but on that should solve the problem...
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
How do I turn the volume down or turn off the beep from my Frigidaire Gallery 5.0 cu. ft. Gas Range when the oven reaches its intended temperature?
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
How to I adjust the flame in a Frigidaire gas oven.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
The oven and broiler elements are not working in my older Frigidaire stove. I suspect a blown fuse.
This is so confusing
You say
"The oven and broiler elements are not working"
Then you say
"Everything works except the burners'.
so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light?
Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange!
Click comment under my answer and also under Vince's and we will get you Fix-Ya.
What is F29 error on Frigidaire professional gas range
F29 on all Frigidaire ranges means there is a communication error between the oven user interface and the touch panel. The control can't do the initial communication. This could be related to a wiring problem or a problem with the touch panel or the oven user interface board. Turn off the power to the range for 30 seconds to clear the code. If it returns, check that the wiring harness is fully seated. Check the wires for continuity and make sure that there is no corrosion on any of the pins. If the error repeats, replace the touch panel. If the error still persists, then replace the user interface board.
Please add a comment with the model of the range for a parts list/diagram.
I hope this helps.
