20 Most Recent
Krups XP1500 & XP1530 Questions & Answers
XP2280. Where can I obtain an owner's manual?
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page
View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
How do I fix error code 12
That is a very uncommon error code. It is not detecting the ejection switch pulse, it may be just a case of dismantling and cleaning and checking the switch operation. It's all internal so you need to remove the housings.
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Grinder
To make it finer you need to remove the top housing and look at the top of the grinder. Notice the white part at the top with an arm on it that engages with the lever from the adjustment knob. You need to remobe the white part from the top of the grinder and turn it back (anti clockwise) a couple of notches and re-engage it. It would pay to make a note of the original position, you cannot move too far from that.
