20 Most Recent DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Questions & Answers
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
DeLonghi... | Answered on Jul 01, 2019
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
DeLonghi... | Answered on Apr 18, 2019
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
DeLonghi... | Answered on Apr 08, 2019
We had excactly the same problem a couple of times recently with a lot of troubleshooting,like adjsusting grinder, reseting the to factory settings, and many more and we end up that it was a problem with pcb control board which lost the preset timing of grinding thus the coffee grinding where about 3-4 sec and the correct one shold be about 8-9 sec. We have here one side which have the control board for your reference.
DeLonghi... | Answered on Mar 11, 2019
Thanks globalautomo!!
It sure looked clean but upon further inspection the tiny hole was not. Boiled it just like you said and immediately it works like it should. My wife is grateful!
DeLonghi... | Answered on Feb 15, 2019
I have the same problem as this after cleaning. The machine won't power on. It does a power on self test and then the grounds tray full or missing light comes on and nothing else can be done.
A friend of mine with a similar machine says hers fixed itself after a while so assume some sensor got jammed/obscured with my over zealous cleaning. However I'm not hopeful. Might try taking it apart.
DeLonghi... | Answered on Jan 05, 2019
3301b6a1-7978-4eec-ae16-e2ae2cedb1d4.gif 2aa5c39d-04a1-4df9-8faa-9f5b1d24b6c3.gif 31d3c870-7c4c-4b12-a4df-5af6c51a7bf7.gif
this is the best thing i found .. i wish it helps :)
Good Luck
DeLonghi... | Answered on Mar 14, 2018
no options but to replace it sorry
DeLonghi... | Answered on Nov 05, 2017
SORRY but FIXYA does not make coffee nor do we repair coffee makers . contact the manufacturer thru their website and ask tech support to assist
DeLonghi... | Answered on Oct 13, 2017
Sensor and clip bad. Check switch
DeLonghi... | Answered on Sep 04, 2017
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
DeLonghi... | Answered on Sep 03, 2017
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
468 questions posted
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Magnifica DeLonghi
  • Magnifica DeLonghi
Most Popular Question
delonghi eam 3400 keeps saying empty
  • Coffee Makers & Espresso Machines
