20 Most Recent
Saeco Vienna Deluxe 708461030122DE Questions & Answers
Hello. I was given the coffee maker below for
To prime machine run the hot water cycle, press the button for hot water and open the steam knob until you get a nice flow of water. It is possible that you grind is too fine, try adjusting it coarser by 2 numbers.
How can I descale my Saeco Vienna without beans in
Hi
Never run descaling solution through the brew unit. You should never descale the machine hot either.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your type of machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles) .
4. Remove water tank and rinse it with fresh water.
5. Refill the water tank with fresh water and place it back on the machine.
6. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set. Done, refill your tank and run some water, and you are ready to go.
Saeco Vienna deluxe leaks from above door panel
If your Saeco Vienna Deluxe espresso machine is experiencing leaks from above the door panel during coffee brewing, even after cleaning and descaling, there could be a few potential causes for this issue. Here are some steps you can take to troubleshoot and address the problem:
- Check Brew Group Seals: The brew group is a critical part of the espresso machine. If the seals or gaskets on the brew group are worn or damaged, they could allow water to leak out during brewing. Inspect the brew group and its components for any visible signs of wear or damage. If necessary, replace the seals or gaskets.
- Check Door Seal: The door seal or gasket that creates a seal between the door and the machine's interior could be compromised. Inspect the door seal for any visible defects, cracks, or damage. If the seal is not making proper contact, it could lead to leaks. Replace the door seal if needed.
- Overflowing Drip Tray: Ensure that the drip tray and the drip tray float are functioning properly. If the drip tray is full or the float is stuck, it could lead to water overflowing from above the door panel. Empty the drip tray and ensure that the float moves freely.
- Brew Unit Alignment: Make sure the brew unit is properly aligned and inserted into the machine. If it's not properly seated, it can cause water to leak during brewing. Remove the brew unit and reinsert it, ensuring that it clicks into place securely.
- Clogged Drainage Channels: Check for any clogs or blockages in the drainage channels or tubes inside the machine. If water is not properly draining, it can result in leaks. Clean out any debris or buildup that you find.
- Water Tank Seating: Ensure that the water tank is properly seated and securely in place. If it's not properly positioned, it can lead to water leaks.
- Internal Hoses and Connections: Inspect the internal hoses and connections for any signs of leaks or loose connections. Tighten any fittings if necessary.
- Professional Service: If the issue persists after checking and addressing the above potential causes, it may be best to seek the assistance of a professional technician or service center that specializes in Saeco espresso machines. They can diagnose and repair more complex issues that might be causing the leaks.
Saeco Odea. Go get ready to make coffee but when I press button to make coffee, ground grains and filter lights flashes alternatively?
Hello! When the ground grains and filter lights on your Saeco Odea coffee machine are flashing alternatively, it usually indicates an issue with the brewing unit or the coffee grounds. Here are a few steps you can take to troubleshoot and resolve the problem:
- Check the coffee grounds: Open the machine's front door and remove the brew group. Check the coffee grounds container to ensure it is not full or clogged. Clean out any excess coffee grounds and ensure that the container is properly inserted.
- Clean the brew group: Thoroughly clean the brew group and its components according to the manufacturer's instructions. Pay special attention to the coffee chute, coffee funnel, and the area where the brew group attaches to the machine. Ensure there are no coffee grounds or debris obstructing the mechanisms.
- Check the water reservoir: Ensure that the water reservoir is filled with enough water and properly inserted into the machine. Sometimes a low water level can trigger error signals.
- Restart the machine: After cleaning and checking all the necessary components, close the front door securely and turn the machine off and then on again. This may reset the error condition.
- Descale the machine: If the above steps do not resolve the issue, it may be necessary to descale the machine. Follow the manufacturer's instructions for descaling your specific model of Saeco Odea.
If the problem persists after performing these steps, it may be necessary to contact Saeco customer support or a qualified technician for further assistance. They will be able to provide more specific guidance based on the model and the nature of the issue you're experiencing.
Phillips saeco syntia coffee machine
If your Philips Saeco Syntia coffee machine is filling up the drip tray too quickly after a period of non-use, there are a few potential causes to consider:
- Drip tray not properly positioned: Make sure the drip tray is correctly placed and aligned within the machine. If it's not positioned properly, it may not collect the excess water as intended.
- Clogged or blocked brew unit or coffee grounds chute: Over time, coffee grounds and oils can accumulate and clog the brew unit or the coffee grounds chute. This can cause excessive water to bypass the proper channels and end up in the drip tray. Clean the brew unit and the coffee grounds chute according to the manufacturer's instructions to ensure proper functioning.
- Faulty water level sensor or float: The coffee machine relies on a water level sensor or float to detect the water level and prevent overflow. If this sensor or float is malfunctioning or stuck, it may not accurately detect the water level, resulting in excessive water in the drip tray. Contact Philips customer support or a qualified technician to diagnose and fix the issue.
- Pump or valve issues: Problems with the pump or valves in the machine can cause water to flow too quickly or improperly, leading to overflow in the drip tray. A professional inspection and repair may be required to address these internal components.
In any case, it's recommended to consult the user manual of your specific model for troubleshooting steps and guidelines provided by the manufacturer. If the issue persists, contacting Philips customer support or reaching out to a professional coffee machine repair service would be advisable to ensure proper diagnosis and resolution of the problem.
Saeco Odea Go Brew Espresso Machine.
It sounds like there may be an issue with the gear alignment or the motor that controls the brew unit. You may want to try resetting the machine to its factory settings to see if that resolves the issue. To do this, follow these steps:
- Turn off the machine and unplug it from the electrical outlet.
- Press and hold the "Espresso" button and the "Hot Water" button at the same time.
- While holding the buttons, plug the machine back in.
- Continue to hold the buttons until the machine beeps and the display shows "Factory settings restored".
If resetting the machine doesn't work, you may need to have a technician take a look at it to diagnose and fix the issue. It's possible that there may be a problem with the motor or gear mechanism that requires replacement or repair.
Saeco Royal Cappuccino Brew unit dumping grinds into machine
It sounds like the brew unit might need to be serviced or replaced. The funnel not lining up properly could indicate a problem with the alignment mechanism or the gears that control the movement of the brew unit. You can try cleaning the inside of the brew unit, checking for any obstructions or damaged parts, and reassembling it carefully to ensure everything is properly aligned. If that doesn't work, it's best to contact a professional for assistance. Saeco authorized service centers or repair shops should be able to diagnose and fix the issue.
Possible to extend the descale cycle on a Saeco Molito?
The descale cycle on the Saeco Molito cannot be extended or programmed for a longer cycle. The frequency of descaling is based on the amount of usage and water hardness, and the machine is designed to prompt for descaling when it's necessary to maintain the machine's performance and longevity. It's important to follow the recommended descaling frequency to prevent damage to the machine and ensure optimal performance. If you're finding that the machine is prompting for descaling too frequently, you may want to consider using a water softener or changing the type of water you're using to reduce the build-up of minerals in the machine.
My Saeco Odea Go makes coffee very slowly
If the water pressure coming out of the steam/hot water arm is fine, then the issue is likely with the brew unit or the grinder. Here are a few things you can check:
- Clean the brew unit: A dirty or clogged brew unit can slow down the flow of water. Remove the brew unit and clean it thoroughly, making sure to remove any coffee residue or buildup.
- Check the grinder: A dull or clogged grinder can also slow down the flow of water. Make sure the grinder is set to the appropriate setting for your coffee beans and check that the grinder is not clogged.
- Check the water flow meter: The water flow meter measures the amount of water flowing through the machine. If it is clogged or damaged, it can affect the flow of water. Try cleaning the water flow meter with a soft-bristled brush and see if that helps.
- Check the water filter: If your machine has a water filter, it may be clogged and affecting the flow of water. Replace the filter if necessary.
If none of these solutions help, it may be a more serious issue and you may need to bring your machine to a professional for repair.
Saeco Royal Professional. It has a false grinder blocked error.
The false grinder blocked error on the Saeco Royal Professional can be caused by several issues. Here are a few things you can try to troubleshoot and fix the problem:
- Check the grinder sensor: The grinder sensor is responsible for detecting if the grinder is blocked. Check if the sensor is dirty or blocked by coffee grounds. Clean the sensor with a dry cloth or brush.
- Check the grinder gears: The grinder gears may be worn out or damaged, preventing the motor from turning the burrs. Check if the gears are damaged or dirty, and clean or replace them if necessary.
- Check the motor: The grinder motor may be faulty and not providing enough power to the burrs. Check if the motor is spinning freely and not making any unusual noises. If the motor is not working correctly, it may need to be replaced.
- Reset the machine: Sometimes, resetting the machine can clear the false error message. Unplug the machine for a few minutes, then plug it back in and see if the error message disappears.
If none of these solutions work, you may need to contact a professional to diagnose and repair the issue.
