20 Most Recent Frigidaire FES367 Electric Kitchen Range Questions & Answers
Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
3/27/2017 8:33:34 PM • Frigidaire... • Answered on Mar 27, 2017
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom, I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off. -Best Regards-
1/17/2014 7:47:30 PM • Frigidaire... • Answered on Jan 17, 2014
KENMORE GR 448LXPQ1 REPLACEMENT GLASS
If your goal is replacement due to cosmetic inconsistency , use DeBruce Polish. This Non-toxic multi-surface cleaner will remove surface micro contaminants that are baked onto the surface. Perfect also for cook tops and stainless steel. You can find at DeBrucepolish.com
1/8/2014 5:29:55 PM • Frigidaire... • Answered on Jan 08, 2014
Oven will not come on. no heat in oven
check out put from clock control (ERC ) then check fan relay control out put it could be one or the other Cheers
12/12/2013 2:11:44 AM • Frigidaire... • Answered on Dec 12, 2013
How do I change an element from my stove which is a deluxe 234 model..very old stove but goe's well
Unplug the range from the wall first. Just raise the cook top and the elements are attached to the bottom of it, probably by four screws. Note how the wires are plugged in then unplug them, unscrew the element that don't work, screw the new one in plug the wires back and put the cook top back down. The wires should have blade connectors to easily unplug and replug.
11/22/2013 9:10:31 PM • Frigidaire... • Answered on Nov 22, 2013
Frigidaire oven won't turn off...Was using it at
Make sure that you actually set that as the temp and not the preheat temp.
10/21/2013 12:51:48 AM • Frigidaire... • Answered on Oct 21, 2013
0answers
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
11/27/2012 2:50:45 PM • Frigidaire... • Answered on Nov 27, 2012
Frigidaire gas stove lggf305mkfk wont stop beeping
Did you recently do a self clean or a programmed cooking setting?
9/7/2012 2:55:09 PM • Frigidaire... • Answered on Sep 07, 2012
2answers
F10 err resulting in beeping
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
8/16/2012 10:23:39 PM • Frigidaire... • Answered on Aug 16, 2012
6answers
Frigidaire electric slide in range - clock and stove won't work
Your going to have to replace the control pane.
11/15/2011 3:19:29 AM • Frigidaire... • Answered on Nov 15, 2011
0answers
My oven will not cut
do you mean the power will not stop on the unit if this is true simply pull the unit out and uplug it. F1 would be a control issue most likely you have a bad control in that unit if you have any further questions message me back and please remember to rank how this opinion has helped it allow me to help others in similar situations Thanks Rick
3/21/2011 12:54:03 AM • Frigidaire... • Answered on Mar 21, 2011
Our oven stopped working, the light comes on still
It would certainly be cheaper for you to order the part and do it yourself. Just type in a search for your entire model number for parts and you should be able to find several sites that offer parts for a range of prices.
11/4/2010 3:52:25 AM • Frigidaire... • Answered on Nov 04, 2010
Hi there: I am having problem with my stove. F1
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
10/4/2010 6:32:39 PM • Frigidaire... • Answered on Oct 04, 2010
Frigidaire FES367ABC oven gives f9 error, door
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 3:37:10 AM • Frigidaire... • Answered on Oct 01, 2010
Frigidaire FES367FCC. Oven is flashing F90.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
10/1/2010 3:37:02 AM • Frigidaire... • Answered on Oct 01, 2010
I have a glass cook top and one of the burners
Good Morning Guest,
Fist of all... Do you know for sure that you Halogen Buner needs replacing...I have found that the Infinity Switch burns out before the element does.
With the power off, remove the back panel.
Open the oven and look up where the top of oven door meets the top of oven. There maybe a screw or 2. also check the back to seeif any screws are there.
You should have a service personel help you do this because if you break it, the project will cost more.
Repace the Infinity switch first then your removal of service top
7/24/2010 2:00:19 PM • Frigidaire... • Answered on Jul 24, 2010
Frigidaire FES367 Electric Kitchen Range Logo
76 questions posted
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
am having problem stove f1
  • Kitchen Ranges
