Heater elements are found in electric ovens, you have a gas oven. It sounds like your main gas valve is not opening because the pilot would light it if it was open. It could be the gas valve itself of the flame sensor. Best to get a tech on it.
Hi - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
If you replaced the control,Check the oven sensor it slides in through the back wall of the oven,looks like a chrome rod sticking out of the wall with a crimped end.
If you have an ohm meter the sensor should ohm out at around 1075 at room temperature(70°F) give or take 25 ohms.
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Send it back and get the correct one. It can't be the same part number if the connections are different. Your old one may have features that his new one doesn't. The one less wire may just be a shared return, but the stove might be needing individual returns. If it is an updated replacement (the listing sometimes says 'compatible with' or 'replaced by', or 'alternative part'), it should come with a wiring schematic.
Please always include full 'make MODEL (what it is)'.
Fixya Expert 'Jorgie the Appliance Guy' will have the answer if it is a shared return but he will need the model number. Edit your post and add it.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
