20 Most Recent
Symbol LS9208 Hands Free Barcode Scanner Questions & Answers
Logo
i'm starting a new material supplied business so we need a free logo
Symbol Model LS 9208, Bar
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
I have a barcode scanner Symbol S/N M1J82M51E.
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles
through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Ls9208 need to press enter after read
If you need to have a carriage return/enter after each bar code scanned, scan the following bar codes (from the Product Reference Guide) in order:
1. <SCAN OPTIONS> (on page 12-9)
2. <DATA> <SUFFIX> (on page 12-10)
3. Enter (on page 12-11)
I require factory reset barcode
The barcode is located in the manual at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6083307apdf&sliceId=&dialogID=27078141&stateId=0%200%2027076163 at the page 45 , the name is "Set Factory Defaults"
PROGRAM FOR SYMBOL TABLE
is it a ps2 connection or usb?
there are instructions here http://www.fluidlife.com/media/pdfs/prod_ls9208_quick_start_guide.pdf
